Seeking B13 bin File for SR20DE NA with Cams - SR20 Forum
Old 06-13-2009, 07:30 AM   #1 (permalink)
Feedback Score: 17 reviews
What are you guys using for a bolt-on B13 with cams (S3s)? How would tuning be different from a bin optimized for stock cams? It's understood that I will raise the idle to 950 RPM and mess with that idle advance table to stabilize the idle a little more.
Thanks in advance for any advice or bins.
Bill
Old 06-13-2009, 11:11 AM   #2 (permalink)
Only thing I've found for cams was one using 370cc injectors.
93 NX2000-7.75@92mph 5SPD SWAP, 2120lbs. JDM Motor, Calumsult Realtime ECU, BC3 cams/gears, CP XTP 9.2:1 pistons, NX DP-100 shot, 333's, N60, Prothane Mounts, ACT Xtreme/sprung 6 puck, Fidanza, PR WAI with JWT POP, 2.5" SSAC, Dynomax 3" muffler, Outlaw Intake Spacers, OEM wires, ngk plugs, UR Pulleys, Walbro 190, ST springs with KYB's, Kinetik KR912, Axis maglites
Old 06-16-2009, 05:36 AM   #3 (permalink)
Bump.
Old 06-27-2009, 07:10 AM   #4 (permalink)
OK -- can you share the bin? At least I can take a look at the timing map.
Thanks.
Bill
Old 06-27-2009, 09:23 AM   #5 (permalink)
http://www.sr20forum.com/attachments...af-c3-cams-bin
Old 06-27-2009, 05:10 PM   #6 (permalink)
Much appreciated.
