S13 redtop launch control? - SR20 Forum
Old 06-29-2009, 04:59 PM   #1 (permalink)
Ive been reading around and I found a launch control Calum posted for a b14. Has anyone developed a launch control for a s13 with a det redtop? What tables did you change and what was the method to it. I tune with nistune and I really would like to make this work on my car.
FlyinF4i is offline   Reply With Quote
Old 07-05-2009, 01:35 AM   #2 (permalink)
Silvia WIP Tuned
I am new to Rom tuning, but I had the same Idea.
My idea was to write a code for a rev limiter in neutral.
The problem is that s13, well in my case doesn't have a clutch in sensor.(JDM Silvia). So it wouldn't work.
Is it possible to write something taking in consideration that if your speed is at zero it limits your revs?
WorkinprogressK is offline   Reply With Quote
Old 07-06-2009, 01:02 AM   #3 (permalink)
Doing this is not as easy as people think it is.It requires rewriting some of the ecu code itself. If you ever take a look at a disassembled bin, it looks like a bunch of jibba jabber
It's doable, you just have to know what you're doing
ghostchild316 is offline   Reply With Quote
Old 07-06-2009, 01:09 AM   #4 (permalink)
TunerCode
What bin are you using? Specifically, what is the 23710-nnnnn part number?
Dave
dfddfd2 is offline   Reply With Quote
Old 07-06-2009, 10:16 AM   #5 (permalink)
SE-R Joe
Feedback Score: 14 reviews
just but a launch control from importintelligence.com its only 229.plus shipping it works great
joe92ser is offline   Reply With Quote
Old 07-06-2009, 11:33 AM   #6 (permalink)
Why buy that when the ecu can be setup to do the same for free?
Put the money towards a realtime ecu instead
Old 07-06-2009, 01:14 PM   #7 (permalink)
Knockoffs are TRASH
i have it.
http://www.youtube.com/watch?v=a00yAs8bcAs
PM me if you need information.
IF YOU HAVE A NISTUNE BOARD - YOU'LL NEED TO CONTACT THE PEOPLE THAT YOU GOT IT THROUGH - THEY WILL HAVE TO MAKE YOU A CUSTOME ENT FILE!
If you use nistune with a calum realtime board - you wont need to change anything.
steverino74 is offline   Reply With Quote
