The bin I've been working on - SR20 Forum
Old 07-23-2009, 01:04 PM   #1 (permalink)
This is my makeshift bin for nitrous and a n60 maf. It has problems so none of you really need to try using it lol
93 NX2000-7.75@92mph 5SPD SWAP, 2120lbs. JDM Motor, Calumsult Realtime ECU, BC3 cams/gears, CP XTP 9.2:1 pistons, NX DP-100 shot, 333's, N60, Prothane Mounts, ACT Xtreme/sprung 6 puck, Fidanza, PR WAI with JWT POP, 2.5" SSAC, Dynomax 3" muffler, Outlaw Intake Spacers, OEM wires, ngk plugs, UR Pulleys, Walbro 190, ST springs with KYB's, Kinetik KR912, Axis maglites
Old 07-23-2009, 01:15 PM   #2 (permalink)
like a stray puppy
Feedback Score: 11 reviews
other than your wacky k value everything I have compared looks right. except your fuel map is a lot different to a stock fuel map.
1993 NX2000: Weekend fun car
1990 Accord: New to me Daily Driver
Octave236 is offline   Reply With Quote
Old 07-23-2009, 01:19 PM   #3 (permalink)
It started out as Calums tuned V2 bin. I haven't touched the fuel map.
Old 07-23-2009, 01:26 PM   #4 (permalink)
You're right they are alot different.
Old 07-23-2009, 01:39 PM   #5 (permalink)
like a stray puppy
but you were using the V2 bin before the MAF swap right? I'm thinking this is a problem with the maf. you should make a trip out here and come get mine it was working a year ago
Old 07-23-2009, 03:55 PM   #6 (permalink)
I don't think it's the maf cause it's running fine now. I just need the correct number for the k value. There's a difference between it running fine now while I'm driving down the road, and what it MIGHT do tommorrow night at the track you know. I was hoping Calum would have chimed in by now but I can wait. If I don't have anything better tommorrow I'll just put the stock one back on before I go to the track.
Old 07-24-2009, 11:35 AM   #7 (permalink)
like a stray puppy
if you go back to the track with the stock maf then here is a bin and XDF i want you to try. you'll have to change over your timing maps for nitrous but it is all pulled from the V2 bin you have.
CRAP it won't let me load an XDF file which is a key factor. you got an email address I can send it that way I guess.
