I need some help. - SR20 Forum
Old 08-19-2009, 11:14 AM   #1 (permalink)
Learning..
I need some help.
Hi everybody, i try to made a bin for my new setup, sometimes work fine 14.7 afr on idle but sometime this change to 16-17 of afr
I try to increase on the primary fuel map gas on wot but my afr still on 12.2
Someone can tell me whats wrong on my bin?
setup is t3/t4 turbo, 8:5.1 CR, z32 maf, STi injectors 520cc at 3 bar.
Thanks.
www.srcomotorsport.com NIStune autorized dealer
robertsr20 is offline   Reply With Quote
Old 08-19-2009, 11:24 AM   #2 (permalink)
ClamSlut
Calum's Avatar
Feedback Score: 26 reviews
B13? Hey how's the Altima stuff working out btw?
Old 08-19-2009, 12:37 PM   #3 (permalink)
Learning..
Yea B13.
The altima stuff work fine, put the jumper to 64k, burn the eproms with my back up and turn on the car and work fine, no more check engine but these project, I will slowly, because even I do not have the complete turbo kit.
Thanks.
Old 08-21-2009, 01:01 PM   #4 (permalink)
Learning..
Any body can help me??
Old 08-21-2009, 05:44 PM   #5 (permalink)
TunerCode
Closed loop is enabled. Is your O2 sensor connected and working?
For the WOT issue, maybe a fuel pressure problem?
Dave
dfddfd2 is offline   Reply With Quote
Old 08-21-2009, 07:44 PM   #6 (permalink)
Learning..
Dave
Yes mi O2 sensor is working, fuel pressure is checked and still fine i think my O2 wideband sensor in condensed because yesterday rained a lot and more later my AFR goin to - - - (very poor) i think is damaged, I'll be change the sensor before continuing.
Thanks.
Old 08-21-2009, 10:54 PM   #7 (permalink)
TunerCode
Your wide band will read lean while the AIV is active. that's probably what you are seeing at idle. When AIV is activated, as long as the throttle stays closed, AIV stays on for 10 minutes. Time how long you see the lean condition at idle, and if it's around 10 minutes, it's the AIV working.
Not sure about your WOT AFR issue. Hopefully you have a way to map trace your fuel map so you can see what's happening.
Dave
Old 08-22-2009, 07:20 PM   #8 (permalink)
Learning..
Dave
Dave is confirmed my O2 wideband sensor is broken, a friend lent me his sensor and my AFR change on idle still on 13.7 - 14.2 and 11.2 on wot.
I'll buy a new wideband sensor, thanks a lot Dave
Old 08-22-2009, 07:36 PM   #9 (permalink)
TunerCode
de nada
