Need help with s14a sr20det backtop - SR20 Forum
Old 09-14-2009, 02:06 PM   #1 (permalink)
Hello i'm from Greece and i have a litle problem. I bought a daughterboard for my s14a ecu a year ago and i have installed it with success. Now i want to upgrade to z32maf 550cc injectors and i face some problems. Some tunes that i found here dont work at all. When i install the eproms the car fails in safe mode(3000 rev limit- very rich) So i order 2 eproms from the original vendor that i bought the daughterboard. He send me the bins with e-mail and i burn them. Now the car works fine under boost revs ok etc but at low rpms it shacks. It doesn't idles, if you try to accelerate slowly it backfires, and generally it doesnt work as it should. I tried to fixed it but when i tried to open it with the tunerpro and a definition file of yours, i found some strange things. Many maps is gonne. for example at the base timing map i only see 255, the fuel map is strange too. I 'll send you the bin to examine it.
bakakas is offline   Reply With Quote
Old 09-14-2009, 02:22 PM   #2 (permalink)
here is the bin
