Calum I have a couple of questions. I found the following tune on the forum and wanted to get your thoughts. My concerns:
http://eccs.hybridka.com/viewtopic.php?f=11&t=1588
I have 11:9 compression he has 11:3 (Which I can fine tune and shouldnt be an issue)
His parameters are in KM/H
to make sure: I need to make sure the distrtibuter is set to stock before i retard the time via the ECU?
If that doesnt work I wanted to use the following stock tune. I was reading about potnetial issues between maps made for 28 ECU and 24ECU? Would it be safe to use the bin to work off of?
http://eccs.hybridka.com/viewtopic.php?t=6
Thanks again for your patience in helping me out. I am getting there
Adam
