Any way to control fans on the S13 ECU ??? I did find this but didn't seem to work for me.. Hooked test light to pin 111 and when throttle cracks open off idle it show a 1/2 sec response I am guessing this is how it works with unmodified code
http://eccs.hybridka.com/viewtopic.php?f=4&t=1696
Anyways look at this see if it make since the pin 111 opens a ground so 12v relay should work...
Chris Allen aka Shaggy
91NX2K 12.6:1CR SR20VE All N1 parts Track Car
06 Dodge Turbo Diesel Chiped to 445HP & 860FT/LB TQ
96 200SX Built GTI-R 497WHP (RIP . Cover of SCC Sep2001)
Suspensions Unlimited Long Travel Sand Rail
92mm Piston GTI-R GT30R F.A.S.T ECU
Building SR20VET for it now and GT35R,Moran 235lb injectors,MS3 ECU I built,VVL Activation via 130kPA & 70%TPS , on E85
