For those wondering how it is that I got 376.35 as the injector value for 370cc, here's how I did it.
I have a N/A rom bin which the K value is 31206 Dec (79E6 Hex) and I have a U12 DET which has a K value of (53E3 Hex) 21475 (just in case it uses the same MAF as the DE). Now, when I would do the formula of changing injectors, I assumed that the DE uses actual 259cc injectors.
Now when I did 259/370 = 0.7
Now when you multiply (k value) 31206 x 0.7= 21844.2 Dec which is 5554 Hex
Now, this isn't right, because the stock U12 is (53E3 Hex) 21475 Dec.
In order to get the same value I had to use this formula
259/376.35= 0.6881892
Now you take the N/A K value 31206 Dec and multiply it by 0.6881892
31206 x 0.6881892= 21475 Dec and that's 53E3 Hex.
Now, this is all on the assumption that the 259cc are infact 259. This is just me throwing out numbers I would have to actually test this to see how accurate it is. But I think it's a good start. What do you guys think?
First, 370s aren't really 370s. I had a set tested and balanced by RC a while back, and while I don't remember what they ended up being it was significantly higher than 370. I don't know how close 259s are to actually being 259s, I've never had a set tested. Its not that big a deal, the ecu can and will adjust up to 20%. After you pick your k number just watch the alpha parameter. It will tell you if you need to go up or down. Adjust the k value to minimze it.
Second, I think you'll find if you use 53E3h in a bluebird rom with a 53.5mm maf, all other things being unchanged, it will run on the lean side. Can you walk through the derivation of your original multiplier, 1.047824 (round it to 1.05, the numbers come out smoother)?
All posts by Calum in this thread are copyrighted by Calum, and cannot be edited, deleted, or copied without his express permission. calum@calumsult.com
So now it would be 22548 x x 0.8808867= 19862 (4D96 Hex)
What do you think? I would have to try this out on a car to be accurately correct. Right now, I'm still looking for a donor car, hopefully by the beginning of next year I will have a few cars to play with.
So now it would be 22548 x 0.8808867= 19862 (4D96 Hex)
Calculated K values are really only good as starting points. You really need to adjust them after running on a wideband o2, etc... from there, keep trimming using the percentage technique. if 10% too rich, lean K value by 10%, etc. keep doing it until it is correct.
however it is not as simple as that, to make things run in harmony, you will have to play with the latency and K value together, if not it will be a new bunch of headache... AF just right at idle, but too rich/lean at WOT, vice versa.
