Old 10-14-2007, 10:14 PM   #1 (permalink)
24/7 Baller!
Center console removal?
Okay so I replaced the bulbs in my gauges and my climate control following Covert's "How To's" but, now what bothers me is the green light coming from my drive indicator (I drive an automatic ) so this all boils down to my question of "How do I remove the center console?" I tried and got the console itself loose, but it was stuck on the parking brake and I couldn't get enough clearance in the front to get it off either.
Any help is greatly appreciated.
Red SE-L
xCONWRATHx is offline   Reply With Quote
Old 10-15-2007, 09:21 PM   #2 (permalink)
24/7 Baller!
bump?
Old 10-15-2007, 10:46 PM   #3 (permalink)
Trader Rating: 16 (100%)
I see people are actually using my writeup
I wish I could help you, but since I don't have an automatic its hard to say... I would just start carefully taking things apart, remember were everything goes though
Old 10-16-2007, 01:29 AM   #4 (permalink)
B14 Interior Designer
i just removed mine tonight lol. 2 screws to the back of the console, but the front screws you cant see required me taking out my front seats to get to them. after that things should be pretty easy.
Originally Posted by SmilyFace View Post
I know that MOMO hubs crush and save you. In case of an accident those long bolts in my hub are supposed to go right thorough my heart... ...so that I don't have to suffer, and die happy.
Joekuh is offline   Reply With Quote
Old 10-16-2007, 09:08 PM   #5 (permalink)
24/7 Baller!
You see, I had gotten to the point where I had removed the six screws from the console itself (two at the front, two at the back, two right in front of the parking brake) but, I couldn't lift it out high enough to get it out over the parking brake itself, it seems like I'd have to take out the majority of the dash just to get down to one or two bulbs...
Old 10-16-2007, 09:58 PM   #6 (permalink)
what are you trying to get to? once you take off the part that has the lil holder in the middle that should pop off and be able to go over the parking brake easily.
Old 10-17-2007, 12:32 AM   #7 (permalink)
24/7 Baller!
so are you saying it comes off in two pieces? or are you pushing it forward somehow as you pulled up? or did I just completely not notice something
whatever I'll try to get back at it on saturday
Old 10-17-2007, 01:00 AM   #8 (permalink)
lol yeah there's 2 pieces to it....one piece that connects from about the shifter forward to underneath your dash, and another little piece that connects from your shifter to the back seat area.
Old 10-17-2007, 09:30 PM   #9 (permalink)
secretweapon
bro its easy to get off.remove the 6 screws take the trim piece off around the shifter and than just pull the whole thing up,pull ur e brake up like maybe half way and the slid the thing up anf foward and move aroun till it comes out.its not a hard thing to do.a retard can do this.and u dont have to remove ur seats,whoever did that wasted alot of time.should about ten minutes to take it out and change the bulb and put it back in.
if u cant figure it out take it to nissan.
adio0102 is offline   Reply With Quote
Old 10-17-2007, 10:34 PM   #10 (permalink)
24/7 Baller!
Chill son, chill. Just trying to figure it out, no need to hate. I'll get it...
Old 10-18-2007, 01:17 AM   #11 (permalink)
24/7 Baller!
And I got it...
Looks pretty good but I might need to make some kind of insert to put in behind the plastic one to try to dim the bulbs down a bit, and you did have to remove the seats in order to get to two screws on either side of the console, thats what I was missing before that had me so confused, thought I'd found them all...
