Old 12-20-2000, 05:10 PM   #1 (permalink)
startup squeal
Getting squealing at startup. I'm used to the startup clatter on my 2000 SE (9K miles). This sounds like a belt. Any ideas?
Old 12-20-2000, 06:37 PM   #2 (permalink)
former pulsar car whore
Check the archieves on SE-r.net. I believe its been covered in there before if I remember correctly from the mailing list.
97 Black SER is offline   Reply With Quote
Old 12-20-2000, 09:50 PM   #3 (permalink)
_______
Mike's Avatar
Trader Rating: 56 (100%)
Dose it happen for a split sec while the starter is cranking?
Mike 98sentraSE Turbo
http://people.ne.mediaone.net/mgoss/Page2.html
Mike is offline   Reply With Quote
Old 12-21-2000, 06:43 AM   #4 (permalink)
Thanks for the response Mike and 97 black SER. I've already had the starter replaced due to its ability to not work when I needed it to. Sometimes the starter clutch would not even grab, it would just spin. It sounds almost like the belts are loose, or they're trying to turn something that really doesn't want to turn, like a bad idler pulley or something. I love everything about my SE except for this. It drives me nuts, and it's embarrassing when I'm giving someone a ride, telling them how great Nissan Sentra's are, they should check them out, yada yada, then it strikes. Sometimes, if it's humid, or if I just washed the car, it can squeal for a long period of time, but only if the engine is cold. If it's been driven recently, it won't do it.
Old 12-21-2000, 06:48 AM   #5 (permalink)
_______
Mike's Avatar
Sounds like your belts are loose. Easy fix. Just pop the hood and tighten them.
Mike
