Go Back   SR20 Forum > Vendor Customer Support > Slowboy Racing
Old 08-06-2007, 11:00 PM   #1 (permalink)
coryb13ser
the proof wizard
Trader Rating: 26 (100%)
quote
how much do your stroker kits go for?
12sec NA
Old 08-07-2007, 12:13 PM   #2 (permalink)
sbr inc
I can get you the BC stroker kit for $ 2450 shipped.
sbr inc is offline   Reply With Quote
Old 08-08-2007, 03:47 AM   #3 (permalink)
coryb13ser
the proof wizard
whats the specs on these? stroke, and comp pistons?
Old 08-08-2007, 09:27 AM   #4 (permalink)
sbr inc
* Ductile iron plasma top rings, tapered second ring, low tension oil rings.
* Typically includes aluminum buttons/rail supports (not locks).
* Fully system balanced and ready to install.
The BC stroker kit for the Nissan SR20DE(T) engine incorporates a 91mm stroke, steel billet crankshaft. Depending on bore size that you decide, the BC kit will take you up to a 2.35L with a safe 90mm bore. The SR20DE(T) kit utilizes premium steel billet connecting rods. As usual, each BC kit features custom CP pistons, wrist pins, full ring pack and buttons. Big time horsepower and torque gains.
Brian Crower SR20 Stroke Spec - 91mm
Old 08-08-2007, 11:27 AM   #5 (permalink)
sr20venosfreak
Will they be any issues fitting it to the sr20ve block.
sr20venosfreak is offline   Reply With Quote
Old 08-08-2007, 11:44 AM   #6 (permalink)
sbr inc
I will have to check with BC but i dont think there should be any problems with fitment issues. I will PM you with what i find out.
Old 08-08-2007, 10:57 PM   #7 (permalink)
coryb13ser
the proof wizard
blocks are the same, as long as the pistons clear the oil squirters
Old 08-09-2007, 12:04 AM   #8 (permalink)
sr20venosfreak
Thats what I ment to ask.If the pistons clears the oil squirters.I'm also intrested in one if these kits but I need to know facts before buying it.I need to stack more money but I'm almost there.
Old 08-09-2007, 12:16 AM   #9 (permalink)
coryb13ser
the proof wizard
well the kit is for de and det, so i would assume it would clear, since the det has them...
Old 08-09-2007, 12:51 AM   #10 (permalink)
sr20venosfreak
I'm thinking of running a stroked motor with nitrios so I don't want high compreesion.I want it to be around 11:3:1.So if I'm correct I will need 10:5:1 compression pistons so the ve could have that compression?How about valve notches?Do they have to be 2mm deeper?Thats what I read some where but I can't remember.
Old 08-09-2007, 09:26 AM   #11 (permalink)
sbr inc
There shouls be no interference with the oil squirters. Are you going to be running a turbo or N/A ? you dont want your compression that high if it is going to be a turbo car.
Old 08-09-2007, 11:53 AM   #12 (permalink)
sr20venosfreak
It's going to be N/A with a 100 shot when needed.
Old 08-10-2007, 12:23 AM   #13 (permalink)
coryb13ser
the proof wizard
atleast go 11.0:1
Old 08-10-2007, 03:09 PM   #14 (permalink)
sr20venosfreak
So what det compression pistons I need so the VE could be at 11:0:1?Also how deep the valve notches should be?
Old 08-11-2007, 12:22 PM   #15 (permalink)
sbr inc
I think with the DE compression for N/A motors i could do a 11:0:1. And they are custom pistons so probably 2mm deep notches.
