B15 tranny w/ vlsd- What year G20s and Sentras - SR20 Forum
Old 02-04-2005, 02:48 AM   #1 (permalink)
RNN14 @ 15 psi
I am about to make a purchase on a B15 tranny w/ vlsd but I would like to make sure and cross reference it to what year G20s and what year Sentras 2.0 can I obtain a B15 tranny with vlsd. Here is my situation... I have a B13 chassis and a GTi-R RNN14 motor swapped into my 92 classic SE-R. I am currently using a B13 tranny until yesterday when it decided to give up and called it quits. I have been researching all night last night and came to a conclusion that everyone pretty much says to go with a B15 tranny w/ vlsd and I was told that I can obtain this tranny from either 1999-2001 G20s and 2000-2001 Sentra 2.0s.... Is this accurate? Please advise and sorry for such a newbie question.
Thanks guys,
Dennis C.
You like PIE?
Dlove3:16 is offline   Reply With Quote
Old 02-04-2005, 03:52 AM   #2 (permalink)
good question. i would also like to know so bump bump bump it up.
alpha_1 is offline   Reply With Quote
Old 02-04-2005, 07:19 AM   #3 (permalink)
Monkey Power
Feedback Score: 6 reviews
you want the 2000-2001 b15 or g20 tranny with the lsd.
94 se-r 342whp 300lbft @ 15psi
92 se-r sr20ve with N1 cams soon to turbo
http://www.cardomain.com/id/cortrim1
www.southern-shift.com
cortrim1 is offline   Reply With Quote
Old 02-04-2005, 07:42 AM   #4 (permalink)
On Vacation
Feedback Score: 10 reviews
1999-2001 G20s
2000-2001 B15 Sentras (2.0 SE)
Manny E.
523 whp & 409 wtq ---RETIRED
SE-Rawkus is offline   Reply With Quote
Old 02-04-2005, 09:09 AM   #5 (permalink)
Feedback Score: 9 reviews
You might want to consider the different gear ratios:
.....................Final drive...1st.....2nd.....3rd.....4th.....5th
1999 G20..............4.176, 3.063, 1.826, 1.286, 0.975, 0.756
2000-2001 G20......4.176, 3.333, 1.955, 1.286, 0.926, 0.756
2000-2001 B15 SE..4.437, 3.333, 1.955, 1.286, 0.926, 0.733
jp314 is offline   Reply With Quote
Old 02-04-2005, 10:05 AM   #6 (permalink)
PLAY MY HEAD, MONKEY!
daveracer's Avatar
Feedback Score: 93 reviews
I was told the 1999 G20 wasn't stronger?
Old 02-04-2005, 10:17 AM   #7 (permalink)
WASHED UP
Originally Posted by SE-Rawkus
1999-2001 G20s
Are all 2k-2k1 sentra 2.0se tranny lsd?
i know only g20'T" tranny are lsd.
Old 02-04-2005, 10:19 AM   #8 (permalink)
No all are not lsd. The only way to tell for sure is to well look at it and find the lsd "bulge" or confirm it is a Performance Package model. These models had side skirts and a spoilor
david is offline   Reply With Quote
Old 02-04-2005, 10:37 AM   #9 (permalink)
WASHED UP
Ok so i guess the lsd has a hump. and non lsd is more flat.Saying that i guess they use different axels just like non lsd b14 trannys.
Old 02-04-2005, 11:02 AM   #10 (permalink)
Grandma's gonna get ya!
coalitionSE-L's Avatar
Do not get a 1999 G20 transmission, it's the same as a B13/B14 transmission.
You want either 2000 or 2001 of both models.
1999 SE-L SR20DET-- Sold!
Old 02-04-2005, 02:31 PM   #11 (permalink)
WASHED UP
Ok so i saw what a b15 tranny with LSD look like .Anyone has pic's on a non lsd b15 tranny?
Old 02-04-2005, 04:19 PM   #12 (permalink)
GT30R'd Up
Feedback Score: 7 reviews
So I hear that the B15 Tranny w/ LSD, The Axle Seal on the Driver side is bigger than the one on the Passenger side. Non LSD are both the same size....Is this true??
Allan
96 SE-R GT30R'd Up
07 G35S Sedan
Nizmonik SE-R is offline   Reply With Quote
Old 02-05-2005, 01:17 AM   #13 (permalink)
RNN14 @ 15 psi
Thats all I need to know. Thank you all
Old 02-05-2005, 01:33 AM   #14 (permalink)
Coropate greed hater
Feedback Score: 3 reviews
Get either 2000-2001 P11 G20t tranny or the 2000-2001 B15 Sentra SE tranny if you want the VLSD.
-The Usual Suspects
Old 02-05-2005, 02:02 AM   #15 (permalink)
RNN14 @ 15 psi
Thank you
Old 03-17-2005, 01:06 PM   #16 (permalink)
RNN14 @ 15 psi
Just for clarification, the transmission that I found came out of a 2000 model G20 but could not verify if it is a G20t or a regular G20. Although, the tranny has a VLSD on it or should I call it a Locking Differential. The G20t is the only model in G20 that has the locking diff? Please advise.
Old 03-17-2005, 02:23 PM   #17 (permalink)
What "they" refer to as a locking differential is just a VLSD. Not 100% on this, but I'm thinking the G20t was the only model with the VLSD. If you have one with a VLSD, it really doesn't matter what it came out of though--you got the VLSD
Old 03-17-2005, 06:40 PM   #18 (permalink)
RNN14 @ 15 psi
So, it will be a bolt on affair to a GTi-R motor(RNN14) aside from minor mods needed to be performed. The tranny came out of a 2000 model G20 and the tranny has vlsd. thanks
Old 03-18-2005, 01:19 AM   #19 (permalink)
Yes, you can absolutely bolt that transmission up to the GTi-R motor. IIRC, there is like one or two bolts that don't go in (just like if you were to use a B13 or B14 tranny on a JDM DET--someone correct me if I'm wrong). To get it mounted and operational in the B13 chassis, there are some slight mods that need to be performed which are explained in a thread that is located in the technical info library.
EDIT: Here's the link http://www.sr20forum.com/driveline-transmission/97257-how-p11-b15-transmission-swap-into-b13-b14-p10.html
Old 03-18-2005, 09:52 AM   #20 (permalink)
2002 g20's also exsist, just so you guys know
2001SEdemBoobs is offline   Reply With Quote
