Old 02-27-2005, 01:09 AM   #1 (permalink)
Trader Rating: 81 (100%)
Ecu pin diagram from FSM
FSM owners... I need your help... I have a 1992 B13 se-r and i need to get the diagram for the ecu pins and their function. I searched the forum and found one for a B14 but it was just showing specific wires needed to hook up the safc and i wasnt even sure if it was the same as the B13. I also need to identify the oxygen sesnor wire at the ecu rather than at the oxygen sensor itself. Thank you in advance.
TURBOSER1 is offline   Reply With Quote
Old 02-27-2005, 02:17 AM   #2 (permalink)
ClamSlut
Calum's Avatar
Approved vendor
Trader Rating: 24 (100%)
O2 is pin 19 IIRC.
calum@calumsult.com
Old 02-27-2005, 02:19 AM   #3 (permalink)
thanks for your prompt reply.... "IIRC" not sure what that means... can you clarify please.
Thanks man!
Old 02-27-2005, 02:31 AM   #4 (permalink)
ClamSlut
Calum's Avatar
Approved vendor
IIRC = If I Recall Correcty.
I looked it up, I was right, 02 = 19.
Heres the rest of the sensors (flip to the right section):
http://web.utk.edu/~cjohns32/ecu_pinout.pdf
I've got the full chart if you need any that are missing, but its not in a scannable format.
Old 02-27-2005, 02:46 AM   #5 (permalink)
Calum, You the man..... Thanks alot for your fast and efficient help man.... I really do appreciate you taking the time to do this.....
Old 02-27-2005, 02:48 AM   #6 (permalink)
I've got the full chart if you need any that are missing, but its not in a scannable format.[/quote]
I'd appreciate that too
Old 02-27-2005, 02:54 AM   #7 (permalink)
ClamSlut
Calum's Avatar
Approved vendor
Sure, for any that are missing just post the pins and I'll look them up, but not tonight, I'm going to bed.
Old 02-27-2005, 10:38 AM   #8 (permalink)
agent camel toe
great response and great member..thanx again turboser for the gauge..looks good with the soon to be vvl turbo
nyce1s.com
R.I.P. RESPECT SR.
93 p10 jdm de--for sale
96 b14 det--for sale
89 formula--sold
next up is a minivan
