Old 02-27-2005, 03:10 PM   #1 (permalink)
SEriouslystrippedsleepeR
Center bore - Can it be enlarged by a dremel?
I am looking into getting some oem miata or BMW wheels and I know that they have a smaller center bore then the sentra. I wanted to know if I can bore the center out with a dremel or other rotary tool. Would there be any problems if the bore wasn't perfectly circular? I had some miata rims on a sentra before but it cost $60 to get it bored out with a CNC lathe machine.
1992 Sentra SE-R: Project Sleeper
2005 Forester XT: Daily Sleeper
omarmipi is offline   Reply With Quote
Old 02-27-2005, 06:04 PM   #2 (permalink)
Master Cunnilingust
Trader Rating: 37 (100%)
$60 for all four? That's cheap, I wouldn't screw with it myself to save $60. It wouldn't have to be perfect since it's toward the center of the wheel, and since the weight is placed on the studs. I don't know how much metal you're going to have to remove, you'd probably burn up a dremel trying to do that. Mine has a flexible spline sleeve that links the motor to the arbor, and I've burned it in half a few times using cutoff discs with it. An air powered die grinder would be tedious unless you've got an awefully big compressor to keep up with it.
- Rob
Old 02-27-2005, 07:24 PM   #3 (permalink)
sleeper
i'd just take it to a machine shop and they can pop it on a lathe and enlarge the bore. If you don't do it perfectly round, you'll jack up the balance of the wheel.
Khiem
'05 Evo
'05 CBR 600RR
Old 02-28-2005, 12:10 PM   #4 (permalink)
I love Katamari
I had thought about doing the same thing as well, but then I thought some more and realized it was not a good idea. Honestly, $60 is cheap, and you'd need a lot of sanding drums, rough stones, etc. - probably $15 worth of cutoff stuff, plus with the added aggravation, you know you'd probably just F something up
save the whales, harpoon fat chicks
Bjorn is offline   Reply With Quote
Old 02-28-2005, 01:37 PM   #5 (permalink)
VE'ed
Trader Rating: 33 (100%)
thats cheap! I took my rims to a rim show to ask them to enlarge 2 rims, he charged me 95 bucks per tire~!!! Those bastards
But what places do you go to get this process done?
Mautai916@yahoo is offline   Reply With Quote
Old 02-28-2005, 02:38 PM   #6 (permalink)
Making the G breathe hard
Jaketips42's Avatar
lol, i tried doing this with corrado g60 wheels, then I realized i would have been there for a while. Trust me when i say that i live by my dremels.
Old 03-01-2005, 01:25 AM   #7 (permalink)
I looked up some machine shops on the yahoo yellow pages and called around. Most people said that they had never done anything like but the one I went to hadn't done it either.
Old 03-01-2005, 01:55 AM   #8 (permalink)
You need to call some wheel repair shops, not machine shops. Did you try your local Wheels America?
4750 Sherwood Lane
Houston, TX 77092
(713) 686-1311
empower99 is offline   Reply With Quote
Old 03-04-2005, 09:41 AM   #9 (permalink)
Yes, but thanks for the advice. Nice bimmer by the way.
