Old 02-28-2005, 05:33 AM   #1 (permalink)
US Air Force
Thrust bearing grease?
When doing a strut install do I need to put grease on the new trust bearings?
thanks
"Warning: Driving this car may give you a reputation to live up to"
1992 NX2000 dealer brochure
luxor is offline   Reply With Quote
Old 02-28-2005, 05:19 PM   #2 (permalink)
Import Tech.
most of them are a sealed unit , they do come appart fairly easy if you want to grease them up a bit , but I rarely grease them unless they feel bad , then I will try and grease , if they still feel bad , replace them ...
SHAWN
Ger-Brock Performance
Portland OR.
'98 Sentra SE.. Time Attack
'06 Pathfinder SE
'93 Infiniti G20 5spd.
My Nissan Site !!
Old 03-01-2005, 03:46 AM   #3 (permalink)
US Air Force
I got all finished installing my new struts and then thought, should I have greased the new thrust bearings? Thanks for the info, that would have sucked If I had to take them back apart.
