Old 02-28-2005, 03:31 PM   #1 (permalink)
Trader Rating: 0 (50%)
compression tester stuck in spark's hole!!!!!
I removed the first spark plug, screw the compression tester in, crank the engine, compression is shown. Relieve the pressure, try to unscrew the tester....... the tester isn't unscrewing... only the rubber hose turnin!!
It's unaccessible by any long noses...
the only hope resting... is reduce the width of my 11" long nose.
Have any idea ?? except removing the head ? i don't have time for that right now and no place too
$pider is offline   Reply With Quote
Old 02-28-2005, 03:33 PM   #2 (permalink)
Tired Greasemonkey
yikes, how tight did you screw it in? dump some wd40 in there overnight and see if that helps if not cut the hose and get some needle nose pliers in there. good luck
Old 02-28-2005, 03:35 PM   #3 (permalink)
Tired Greasemonkey
worse comes to worse you could probably get a reverse thread easy out or drill , but then you have to worry about shavings...
Old 02-28-2005, 04:19 PM   #4 (permalink)
cut hose
go get a square bar, 1/2 inch on e/side, about 12 inches or so long.
take a grinder and grind all 4 sides it so it tapers in. at the end of the taper should be about 3/8 - 5/16 or so square. then put a point on the end.
pound it in and un screw.
The idea is just like those screw extractors but only bigger and longer (LOL, thats what she said last night)
For reference look at Snap-On product #: SR40K
2001 White SE, SR20DE powered, 143 WHP (summer car)
1988 Mazda 323, 1.6 8-valve motor, 82 CHP (2004 winter beater - RIP)
1993 Nissan Pathfinder, VG30E (Tow Truck + Camping mobile, RIP)
1995 Infinity G20T, Manual + SR20DE (Wife's car)
1989 Mercedes Benz 190E (Pimpin' Winta' Beata'; RIP)
2006 VW Golf TDI (Can't beat 45 MPG!)
1994 Chevy Suburban Diesel (6.5L @ 18MPG @ 400 FT-LB or torque)
Kick Ass Matt is offline   Reply With Quote
Old 02-28-2005, 07:02 PM   #5 (permalink)
the spookman
This happened to me however, i noticed my compression tester actually had a hex nut on it that would let you get a bit i think 11/16s or somethin down there to unscrew the tester. Does yours have it?
05 Legacy GT
93 NX2000 w/VE
(\__/)
(O.o )
Old 03-01-2005, 02:38 AM   #6 (permalink)
chi-town ser
try to stick 2 screwdrivers down on each side and squeeze together while turning--
"A man is as faithful as his options" -Chris Rock
Pics of Red Heat
9double8 is offline   Reply With Quote
Old 03-01-2005, 10:07 AM   #7 (permalink)
Yes, screwdrivers or try to shave down long needlenose pliers to fit. Screwdriver always worked for me.
Old 03-01-2005, 11:24 AM   #8 (permalink)
They're just cones!
I JB-Welded a socket on to mine when the hose ripped out.
Matt
Boosted as of 11/15/05
Driven97 is offline   Reply With Quote
Old 03-01-2005, 02:52 PM   #9 (permalink)
Making the G breathe hard
Jaketips42's Avatar
Well, did you get it out?
Old 03-01-2005, 04:18 PM   #10 (permalink)
SHIFT_2.0
damn. well we always do comp. test on my friends whips and one dude that got it stuck in his crx. tried glueing it and still couldint get it out. so he drop on 3 cyl. around the block and tried it and it came out . i dnt know if it relieve the pressure or what but it workd. and my other friend got it stuc in his lude and he just kept trying , just screw the hose in and push down and pull up kinda hard at angles and he got it after 30 mins.
The Whip:
before
now
After (comming soon)
StevenLK is offline   Reply With Quote
Old 03-02-2005, 09:03 AM   #11 (permalink)
nope, i didn't retry yet..
what is that "go get a square bar, 1/2 inch on e/side, about 12 inches" Kick ass math ?
Screwdriver dont work...
the best result i had was with a copper pipe cutted in 2 pieces with hyper crazy glue..
the copper twist!! but not the spark
next time i will put JB weld i think maybe it will work.
Mechanical shop here don't know how to do it...
Old 03-02-2005, 09:13 AM   #12 (permalink)
La noche, you mean... i remove the whole rubber hose and a hex nut suppose to be there ?
Old 03-02-2005, 04:00 PM   #13 (permalink)
the spookman
yes. ill take a picture of mine to show you in a little bit
Old 03-02-2005, 05:08 PM   #14 (permalink)
THE HEX tool did IT!!!!
there's no hex nut but it untwist anyways
thanks la Noche
I really appreciate.. i will be able to ride my car 2 more weeks before i got my license removed
Old 03-02-2005, 06:08 PM   #15 (permalink)
the spookman
No problem man
