Old 02-28-2005, 05:31 PM   #1 (permalink)
Air Force SE-R freak!!!!!
Dick's Avatar
Trader Rating: 47 (100%)
Hotshot install help for 95' se-r
1. Does the O2 sensor actually have to be spliced and lengthened?
2. Where do I locate the O2 sensor?
3. Is it better to plug the egr valve on the header? (already gonna plug up the AIV hole)
Any other tips and help is greatly appreciated!
95' b14 SE-R: sr20ve/sr16ve N1 cams/BC S&R/SuperTech +1&2 valves/Fuji header/3" exhaust/Calum real time/N60 short ram with JWT POP/Gspec pully set/Fidanza fly/Gspec stage 3 clutch/B&M SS/Tien basics...
93' b13 SE-R: Miss shifted into 2nd after 15 minutes of driving...New engine now
95' 240sx SE: AEM intake with POP charger/ cat-back
www.rapidcustoms.com
Dick is offline   Reply With Quote
Old 02-28-2005, 06:11 PM   #2 (permalink)
eric96ser's Avatar
Trader Rating: 16 (100%)
1. No, you don't have to lengthen the wires
2. The O2 will be in roughly the same place
3. Leave the EGR connected.
1991 Sentra SE-R
The community is here.
Old 02-28-2005, 06:17 PM   #3 (permalink)
i smell that whore.
Trader Rating: 32 (100%)
1. my o2 sensor was long enough to to still attach to the bracket on the "black box", but it is super tight. if you want some slack, you can lengthen it, i guess.
2. the o2 sensor screws into the hole that is the same size as the o2 sensor. look at my thread that you posted in earlier for reference. it should be the same.
3. if you plug the egr bung on the header, you will need to block off the rest of the egr system. i was thinking about doing this when i was having trouble getting the egr fitting off the stock mani. here's a hint that i picked up on my header this past weekend: if you are having trouble getting the egr fitting off the stock mani, DON"T strip the bolt. undo all the nuts that bolt the manifold on, then unbolt it from the secondary, and jiggle that bastard around. that's what i had to do to break the rust.
hope this helps. - jeff
jeffinbham is offline   Reply With Quote
