Old 03-01-2005, 12:15 PM   #1 (permalink)
Motor mounts for auto to 5 speed swap
I have spent the last 20 mins looking for this info. which motor mounts will switch out in my auto to 5 speed swap. the drivers side mount came with the tranny that I bought. but the cross member mounts are the ones that I am not sure of.
also with the 5speed cross member out of a 1.6 work in the 2.0?
thanks
chui is offline   Reply With Quote
Old 03-01-2005, 12:42 PM   #2 (permalink)
You will need to swap the cross member from a 5 speed.
Paul
1992 Sentra SE-R
1992 240SX HB
1993 Sentra SE-R (Sold)
1992 Sentra XE (Sold)
B13SentraXE is offline   Reply With Quote
Old 03-01-2005, 01:06 PM   #3 (permalink)
Monkey Power
you will need a sr20 cross member, motor mounts and the drivers side motor mount cover. the auto cover is different from the manual.
94 se-r 342whp 289lbft @ 15psi
92 se-r sr20ve with N1 cams
http://www.cardomain.com/id/cortrim1
www.southern-shift.com
cortrim1 is offline   Reply With Quote
Old 03-01-2005, 10:02 PM   #4 (permalink)
Well I got that from here: http://www.sr20forum.com/technical-information-library/87887-howto-1-6-ga16de-2-0-sr20de-t-swap.html
Item:SE-R Cross Member
Description:Only needed if swapping from AUTOMATIC to MANUAL! If you are going from a 1.6 5spd to a 2.0 5spd no need to purchase this. There seems to be alot of confusion about this on the forums.
Old 03-02-2005, 12:08 AM   #5 (permalink)
Master Cunnilingust
Trader Rating: 37 (100%)
I swear I've posted this info before.
Everything you EVER wanted to know about B13 engine mounts!
All B13's came with the same crossmember, regardless what engine it had and only varied between auto and manual trannies. Manual Part #11240-50Y00 Auto part # 11240-50Y10.
Auto's didn't have a front crossmember mount. The mount is the same for both GA and SR manual trannies, but the bracket it bolts to is different between engines. GA part # 11356-0M000 SR part # 11356-58Y00
The rear crossmember mount is the same for both engines, but differs between auto and manual trannies. Manual part # 11320-0M002 Auto part # 11320-50Y11
The bracket that joins this mount to the engine is different for numerous possible engine/tranny configurations. GA16 manual part # 11332-0M000 GA16 3 speed auto part # 11332-50Y21 GA16 4 speed auto part # 11332-0M010 SR manual part # 11332-58Y00 SR auto part # 11332-58Y10
The transmission mount is different for numerous possible engine/tranny combinations. GA16 4 speed manual part # 11220-50Y00 GA16 5 speed manual part # 11220-50Y05 GA16 3 speed auto part # 11220-62R00 GA16 4 speed auto part # 11220-0M010 SR manual part # 11220-58Y00 SR auto part # 11220-0M810
The bracket that joins this mount to the chassis differs between auto and manual but is the same for GA and SR engines. Manual part # 11253-50Y01 Auto part # 11253-50Y11
The passenger's side engine mount is different for each engine, and the brackets are different for each engine. The only thing they share are the pair of flat link bars, referred to as "Engine mount stoppers" and those are part # 11215-50Y10. GA engine mount part # 11210-0M600 SR engine mount part # 11210-0M800 GA mount bracket part # 11231-50Y00 GA engine stay bracket part # 11237-57Y01 SR mount bracket part # 11231-58Y20 (The SR doesn't have an engine stay bracket).
- Rob
Old 03-02-2005, 12:28 PM   #6 (permalink)
Toolapcfan
thanks so much that is the info that I have been searching for
thanks
