Old 03-01-2005, 10:06 PM   #1 (permalink)
Forever slow
Are JDM Low mileage engines reliable?
I was wondering if JDM low mileage engines are reliable. I've seen them go for 300-400 bucks, with under 50k miles.... I dont see why they're so cheap, yet people want 300-400 for usdm sr20s with around or over 100k miles? Ive heard of people blowing the motors after not too long, but then again, i know not every motor is going to be perfect. You might get one that somebody didnt take care of like changing oil as recommended or what ever. But just for yalls input, what do you think. Are they reliable? Any downsides to a low mileage JDM? Has anyone had any problems with them? Thanks
#1 -1993 Classic XE SOLD
#2 -1992 Classic SE-R SOLD to Autoxse-r
#3 -1993 Classic SE-R SOLD
-2002 GMC Sonoma 4.3 V6 - The DD
-1988 Kawasaki EX500 - The newest money trap
Is it Possible to use a TMIC and FMIC?!?
intiractive is offline   Reply With Quote
Old 03-01-2005, 11:06 PM   #2 (permalink)
agent camel toe
i had my boy buy one 3 years ago and its still running..he works at jiffy lube so the oils and maintenence are a+.he also lives in florida now and hes been driving it for 43k miles so far and he has no problems.o yeah u wont pass emmissions but its ok.so just give it a tune up and ur good.i would change the water pump ** installing the new motor.compared to my old ser,he would beat me by 3 cars on the highway when we just finished the swap.its pretty much worth it because of the money
nyce1s.com
R.I.P. RESPECT SR.
93 p10 jdm de--for sale
96 b14 det--for sale
89 formula--sold
next up is a minivan
Old 03-01-2005, 11:18 PM   #3 (permalink)
The Groove Master
Rittmeister's Avatar
Search and you shall find.
Many, many JDM SR20DE motors have been swapped into USDM cars and are still running just fine.
1990 240SR - the DET has landed.
Kent's Funkay Disco
Old 03-01-2005, 11:24 PM   #4 (permalink)
Forever slow
yeah im not worried about emissions, my county doesnt check for them, and besides, its only for 95 and up (obd2) motors. lookin to buy a 91-93 highport for my 92 ser. thanks for the reply
Old 03-01-2005, 11:26 PM   #5 (permalink)
agent camel toe
if ur on a budget or are just wanting a fresh motor get one..their pretty good..thats my third choice if my vvl does not fall thur..try www.jdmenginedepot.com
Old 03-01-2005, 11:29 PM   #6 (permalink)
aka Mr Ryte on G20.net
Simple economics:supply and demand. SR20's are pretty strong and durable. People only buy another if they blow the one that they have.........
.....or if they want one with a little more compression(10:1) or a VE(190 hp).
Vehicle:1995 Dark Green Infiniti G20
Real name:Howard Wright
Current mods:91 intake cam at 19* degrees, TopSpeed header, M3-style rear wing, P11 rims, *Recaro LS-L seats*
I.C.E.:Pioneer DEH-P6800MP CD/MP3 HU, Audiobahn AS65Q 6.5" components in front & back....HELLZ YEAH!!!!
"THOU SHALT NOT MOD THAT WHICH THY CANNOT MAINTAIN" -thus speaketh Mr. Ryte
howard_w13 is offline   Reply With Quote
Old 03-01-2005, 11:56 PM   #7 (permalink)
Professor Dingbat
If you are swapping a JDM in, just be sure to check that the lower oil pan isn't dented (may cause oil starvation and cause you to wreck your 'new' motor) and it would not be a bad idea to check the rod bearings out. Here is what some looked like out of a JDM engine:
Not too badly damaged, but something that is worth checking if you have the means to do so. If you have to pay a professional to remove, inspect and possibly replace the bearings, the JDM swap loses some of its cost effectiveness. If you can do it yourself, it will cost less than $50.
Old 03-02-2005, 12:19 AM   #8 (permalink)
Forever slow
yeah i've heard it mentioned a couple times of people having rod bearings go bad in jdm engines... but then again not every engine you buy is gonna be perfect yeah i checked http://www.soshinusa.com and they want 395 for a 91-94 sr20 plus 140 shipping to a residential address. Ive also heard that soko motors are real good. Guess i'll just have to try and hope for the best. Thanks for the help
Old 03-02-2005, 12:40 AM   #9 (permalink)
i smell that whore.
Trader Rating: 32 (100%)
trying to educate myself here, but what causes these rod bearings to wear like that, why doesn't it happen on a regular usdm engine, or at least to such a degree?
jeffinbham is offline   Reply With Quote
Old 03-02-2005, 01:05 AM   #10 (permalink)
Professor Dingbat
Wear like that is not exclusive to JDM engines, in fact, spun rod bearings are the reason for a good number of the USDM SR20s that need to be replaced. What does them in is extended high RPM use and or oil starvation.
Old 03-02-2005, 08:43 AM   #11 (permalink)
Monkey Power
I dropped in a jdm motor in my se-r a feew weeks ago. I will be putting the turbo stuff on this weekend. I did take the time to inspect the bearings when I had the pans off the to tap the block. the bearings looked new in my motor but I also know my motor was off a automatic car.
94 se-r 342whp 289lbft @ 15psi
92 se-r sr20ve with N1 cams
http://www.cardomain.com/id/cortrim1
www.southern-shift.com
cortrim1 is offline   Reply With Quote
Old 03-02-2005, 11:57 AM   #12 (permalink)
NeoVVL Egg
Well, I purchased a soko engine after my usdm threw a rod bearing after 107k. Then, I put in a jdm engine from soko which had a perfect oil pan and threw a rod after 20k of use. However, the first 5 miles of driving the engine underwent was pretty much without oil. The mechanic that did the swap forgot to thread the drain plug on properly, so it worked itself off and all the oil drained out. Once I got home, i checked, and the plug was gone and the engine was empty. I attribute his idiocy to the demise of my engine. John
-John-
1992 Nx2000
Sr16ve, Hotshot CAI, VE Exh. Manifold w/hotshot downpipe, 2.5" Megan Racing cat-back, msd window switch, nismo fpr, eibach pro-kits and kyb gr2's, b14 se-r Wheels, Exxd Ecu.
NismoNx2000 is offline   Reply With Quote
Old 03-02-2005, 12:09 PM   #13 (permalink)
Forever slow
damn i'd go back up there with a baseball bat and demand some $$$ . never get between a man and his money, his chick, or his car.
Old 03-02-2005, 03:34 PM   #14 (permalink)
70K on my JDM engine and counting no problems so far with it.
Phxdude is offline   Reply With Quote
Old 03-03-2005, 12:11 AM   #15 (permalink)
newbie
Pretty White's Avatar
They seem stout. The JDMs'.
Originally Posted by sonny
Old 03-03-2005, 09:17 AM   #16 (permalink)
NX2000 Racer
Greg Amy's Avatar
I bought a used JDM engine from Chris at SR20Development last Fall to use as a baseline for building a race engine. When we pulled it apart it was "clean as a whistle", no evidence of overhating, no problems found, great shape. Had 30K miles on it, I think?
I would have had no problems just changing the oil and tossing it into a street car. - GA
Kakashi Racing T-Shirts Now Available!
http://www.kakashiracing.com/tshirts.html
2006 ARRC/NARRC/NERCC ITA Champions!
My lug nuts have more torque than your Honda engine!
Greg Amy is offline   Reply With Quote
Old 03-03-2005, 10:25 AM   #17 (permalink)
soshinusa and soko are the same company. soshin is in so-cal soko is in chicago.
oneSIX is offline   Reply With Quote
