Old 03-02-2005, 03:27 PM   #1 (permalink)
Air Force SE-R freak!!!!!
Dick's Avatar
Trader Rating: 47 (100%)
O2 sensor on Hotshot header
I just installed a Hotshot header on my 200sx se-r. I kept reading about people having to move the sensor and get it welded somewhere else. It seems that I do not have to do this. The O2 sensor wire on the header is stretched as far as is can go and is on but, there is no give on the wire it is very tight. Will this be a problem later on? What should I do?
95' b14 SE-R: sr20ve/sr16ve N1 cams/BC S&R/SuperTech +1&2 valves/Fuji header/3" exhaust/Calum real time/N60 short ram with JWT POP/Gspec pully set/Fidanza fly/Gspec stage 3 clutch/B&M SS/Tien basics...
93' b13 SE-R: Miss shifted into 2nd after 15 minutes of driving...New engine now
95' 240sx SE: AEM intake with POP charger/ cat-back
www.rapidcustoms.com
Dick is offline   Reply With Quote
