Okay this makes about no sense whatsoever. I installed my HS intake today and it required taking off the negative battery terminal. The car started up just fine with no problems before. As soon as we got it all installed...nothing. I get dash lights, but no crank or anything. WTF!? My roommate and I think it has something to do with the ground wire that connects to the negative batt terminal, frame and motor. We cleaned all the connections and still no luck. WTF!!! Someone please help me out here.
-Todd
-06 EVO IX RS
-93 SE-R (gone, but not forgotten)
-69 Camaro SS (project car)
Missing my sr20 b14, but still showing some love. Possible new project when I return!
Old car: 1999 Sentra SE-L Turbo: USDM sr20de, t25 turbo, hot shot intercooler kit, BIG ass fmic, nismo fpr, autometer fp gauge/boost gauge, mbc set at stock boost for now! 7psi= more traction>11psi=less traction.
Well 10 min before installing the Hotshot intake...the car was started up a few times. Doesn't make sense.
Someone I spoke with told me I might've knocked a starter wire loose on the back of the IM. Are the starter wires behind the IM? I installed a new line for the intake that runs to the back of the IM.
jack the car up to where you can see the starter then make sure the single wire(smaller wire) is attached to the starter. it attches either by a grey pleg about 2 inches off the starter or a spade connector directly to the starter.
1992 nx2000:White: Sold
its not who you do in life, its who you leave behind. Jerry James Hays 9/1/1982-5/14/2006 Danielle Wilson 2/10/07
5 spd. Yeah we're going to have to wait until tomorrow when I have some light. Thanks for the reply. Hopefully it's something simple like a wire knocked loose.
try jacking the car up on the pass. side and see if it starts......if it does then try a new battery ground, i know it sounds funny, but thats what me and some friends had to do to figure out that one of our cars had that problem, ytry it hope it helps.
ALL FAST CARS GO TO HEAVEN!
GAINING RESPECT ONE PSI @A TIME!
[color=red]
1991 SE-R----R.I.P.
2008 BMW 335xi---daily beater
look at the maf connections first.y not remove the intake and install the old parts again, and if it starts then at least u can drive the classic...stay away from hondas,u have a classic. u need a digi cam tohelp us see what ur looking at.the starter wire is down pretty far from the intake.ur starter has 2 wires i believe.follow the wires and see.u state that ur car does not start but ur getting power?check the fuses
Originally Posted by paNX2K&SE-R
nyce1s.com
R.I.P. RESPECT SR.
93 p10 jdm de--for sale
96 b14 det--for sale
89 formula--sold
next up is a minivan
Not to be mean... but have you tried jumpstarting? Sometimes disconnecting battery can accidentally drain it, worth a shot if you havent tried. And if it works youll be glad you didnt go change a starter for nothing.
Conan
Yeah I already jumpstarted it. I have a battery charger with jump. Didn't help at all. Like I mentioned before, I get dash and headlights, just no crank.
I had this happen where everything else would come on but the car wouldn't start. I cleaned the battery terminals, especially the negative, but the car still wouldn't start sometimes. So I went under the car and cleaned everthing in terms of wiring that connected to the starter. That includes the bolts, washers, ring terminals, and especially the pieces coming off of the starter. Kinda a bitch to do but my car has started up everytime since then.
Ben
'05 Subaru WRX STi
'93 SE-R Rocketsled (SOLD)
Drive it like you stole it (or at least try to before it breaks)
We got it figured out! The starter wire connection worked itself loose. Probably just pushing the motor around to get that intake manifold vaccum line on.
