Old 03-04-2005, 11:01 AM   #1 (permalink)
Interesting Suspension Link
http://www.pistonheads.com/gassing/t...5872&f=135&h=0
I came across this link and as Websense at work is stopping me from using G20 I thought I would ask all you track junkies about the views in here. I have a P10 lowport with the same spring rates as the eGT Primera to focus it on one model. I want to get a good ride on the comfortable side of stiff, as I get enough complaints from my wife about the harshness already. I am getting her round to the idea that 108K miles means the suspension is tired and needs updating... LOL. So I want to keep the comfort and put lowering springs on it. I am thinking of Eibach 30 mm drop as progressive gives more comfort, but this has me thinking about the sway bar balance.
Any thoughts about the relevance of that thread to a P10?? in tired factory condition.
Mike
UK-SRi is offline   Reply With Quote
Old 03-04-2005, 11:18 AM   #2 (permalink)
I love Katamari
if your oversteer/understeer balance is right now, it'll probably be right after you swap springs (assuming you don't put 1000# springs in the rear). In that link, it sounds like the guy has an endlink binding, thus causing his rear sway to go infinitely stiff - so I don't think you have to worry about that. You should look into getting some new bushings - it sounds like you should stick with OEM rubber for the most part, but you can swap the anti-roll bar bushings for polyurethane and maybe replace the endlinks with heim joints and not have it impact ride quality
save the whales, harpoon fat chicks
Bjorn is offline   Reply With Quote
