If the window is actually off the track, it is a simple, yet difficult task. Obviously, you'll have to take your door panel off, etc. Then, you'll have to somehow fit your hands into the holes they build into the inside door to try and put the window back on the tracks. The window will try and catch, so be careful with it. It will take more time to figure out how to do it, rather than actually doing it.
Corey
