Old 03-24-2005, 08:31 PM   #1 (permalink)
Whut?That Ain't No Hondah
Overheating issue.... only 1 change the chasis.
ok heres the deal...
I had this same setup (SR20DE-T, modine double core radiator, and both fans on a switch to run when I flip it)
So I had this setup in my old NX1600, then it went into my B13 Sentra SE-R. And now I'm back into an NX2000. And it likes to over heat, never had this problem in either of my old cars, nothings changed in the setup what so ever.
Is it possible that the single wire water temp sensor is different between the 91-92 cars then the 93 cars?
Heres what I've done in attempt to solve this issue. Drained and refilled radiator. Bleed/burped air out of the system. Installed my old NX1600 hood w/ the WRX hoodscoop turned backwards for use as a heat extractor. Drilled about 6 holes in the front bumper and removed the foam behind the bumper to allow easy flow of air. and of coarse running both fans and my heater full blast.
So driving 30-40mph the car was fine. Sitting at a light the temp needle would start to rise. Driving 60+mph on the highway and the needle would rise to H.
Currently I removed the thermostat and am going to see how this goes. Car came up to temperature super fast after it had been sitting for approx 3 hours. It holds dead in the middle while driving at 30-40mph speeds around town without the fans. Sitting at a light the needle would start to rise, but when I switched on the fans, it drop'd back down to the middle. I'm about to go out onto the highway and see how it does.
Any suggestions?? Is it possible my water pump is toast? Or would the car just straight up overheat when driving? Is it possible the temp gauge sensors are different?
1990 2+2 TwinTurbo 300zx
1993 NX2000 (JDM SR20DE-T)
1.6 to DET Swap
Engine Removal Writeup
NissanWar.Com - Pick the Nice from Rice
Like Boxing? Check out FightJudge.com
Crim is offline   Reply With Quote
Old 03-24-2005, 08:37 PM   #2 (permalink)
Formerly 93veilside240sx
try replacing the t-stat
MarcTheNarc is offline   Reply With Quote
Old 03-24-2005, 09:24 PM   #3 (permalink)
a real egg-head
did you keep using the same radiator through out these changes?
-Mike
1992 NX2000, 1998 Honda Civic
60' 1.997 --- 1/8mi 8.387 @ 84.15--- 1/4mi 13.095 @ 103.29 mph
Click here to see my nx2000!
nx2000racer is offline   Reply With Quote
Old 03-25-2005, 01:03 AM   #4 (permalink)
same radiator, NX2000 double core modine radiator.
I took the car out tonight running w/o a thermostat. It hits warm (middle on the gauge) in the amount of time it takes me to back the car out of the garage and drive to the top of my driveway. It holds there with the fans on, and I got stuck for ~20-30 mins in traffic on the hwy bumper to bumper and it didn't overheat once.
Old 03-25-2005, 01:26 AM   #5 (permalink)
banned
Trader Rating: 31 (100%)
There... You solved the problem... Sticky thermostat...
Wicked R is offline   Reply With Quote
Old 03-25-2005, 01:34 AM   #6 (permalink)
why not leave the fans running the whole time? asking because i don't know the answer.
Egg_Sauce01 is offline   Reply With Quote
Old 03-25-2005, 10:23 AM   #7 (permalink)
banned
I did that... and let me tell you it sucks doing that... I would watch my water temps rise when going over 35 mph, I attributed this to the amount of wind hitting the front of the car overpowered the amount of air the fans were able to move... thus air would back up so to speak... Hence why the ecu shuts off the fans after 30mph if I recall correctly...
Cheers-
E
Old 03-25-2005, 12:03 PM   #8 (permalink)
hm that is actually a good point. never knew that.
