Old 01-09-2002, 08:57 PM   #21 (permalink)
Kjopi- i'm very interested in your setup and how you're not using the jwt ecu...I swear when i asked on this board if there were other ways of going turbo without a jwt ecu everyone said no...What all are you using manage your fuel ? just the afc??
stankser is offline   Reply With Quote
Old 01-10-2002, 07:45 AM   #22 (permalink)
Bad Banana
How Much and from where?
www.boostednx.nismo.org
Loe Lyf is offline   Reply With Quote
Old 01-10-2002, 11:54 AM   #23 (permalink)
yah....all i have for fuel management is the S-AFC on a stock ecu. i also put in a bbk fuel pump, and the 32lb injectors of course, but the afc is all that manages the fuel....no need for the jwt ecu.
kjopi -sleeper- is offline   Reply With Quote
Old 01-10-2002, 06:03 PM   #24 (permalink)
what kind of turbo setup are you running??? HOw difficult was the tuning since your were using the afc???..
Old 01-10-2002, 06:28 PM   #25 (permalink)
i'm running a stock GTIR turbo manifold, and a stock T28 GTIR turbo. it was a little tricky at first to tune, but once i got the hang of it it works perfectly....it'll be dyno tuned later on this month, but so far so good...i was very suprised with how well it's running.
Old 01-29-2002, 04:42 PM   #26 (permalink)
El Chingon
You're running a DET ECU, though, right?
David De Anda
A buttload of black smoke....
nsracer is offline   Reply With Quote
Old 01-29-2002, 05:14 PM   #27 (permalink)
Who ate my sandwich?
Yes!!! I always thought that you could get away with the AFC only to run boost, but like everyone else that's asked the answer has always been a firm "NO"! I wonder if you can locate a JWT ecu and swap it on the dyno and maybe compare the results between the AFC tuned car and the JWT tuned car. Think this would be possible?
DOT Approved
http://www.imagestation.com/picture/...2/fd8df271.jpg
92 NX2000...14.545 @ 95.57 mph
www.vcmc.ca
Son Of Skyline is offline   Reply With Quote
Old 01-30-2002, 11:14 AM   #28 (permalink)
El Chingon
But wait a minute.. I'm pretty sure he's running a DET ECU. NOT a USDM N/A ECU. I've seen that done before and it works pretty well, but only if you're using the DET ECU. This is because the DET ECU already has fuel and timing maps for a turbo; the N/A ECU does not. That's why you've been told not to use the S-AFC to control a turbo (because you're still running on N/A fuel and timing maps). But, if you wanna try, go ahead and let us know of your results
Old 01-31-2002, 01:48 AM   #29 (permalink)
Kjopi,
About the self done SS, cool!!!!
I had a pacesetter on order from JCW and it was cancelled. Looks like I'll try what you did on my OEM shifter.
Dave
1991 SE-R 160K miles, OEM/ghetto SS, ES susp bshgs
1991 240SX - JWT ECU, 52K original miles!
1992 Geo Metro, 204K miles, orig clutch, GTI sway bars
2001 PT Cruiser- Taupe limited 5spd
Probedude is offline   Reply With Quote
Old 02-01-2002, 01:44 AM   #30 (permalink)
You're my boy blu!!!!
Kjopi
I know the speed rev meter that apexi makes bypasses the top speed govenor, does the s-afc do the same thing
camoser is offline   Reply With Quote
Old 02-05-2002, 12:56 PM   #31 (permalink)
SR20DEEP N.Y.C.
IS THAT A SHIFT LIGHT ON THE STEERING COLUM
SR20DEEP N.Y.C.
LOCK IT UP!
DEAD SE-RIOUS is offline   Reply With Quote
Old 02-05-2002, 12:57 PM   #32 (permalink)
SR20DEEP N.Y.C.
AND IF IT IS HOW CAN I BE DOWN
