Old 01-02-2002, 07:25 PM   #1 (permalink)
Se-RiousRacer
Anyone using an Apexi S-AFC
Hey guys is there any of you using this little device????Ive heard since we have a maf that the s-afc can be used to manipulate it???Is this true ...If anyone has this did you see any gains in performance or was it bought for the cool little screen..lol???
White 96 Se-R=Totaled
Green 96 Se-R=Gone
White 93 S13= Sold
Se-RiousRacer is offline   Reply With Quote
Old 01-02-2002, 08:10 PM   #2 (permalink)
Se-Racer
I have one but haven't been to the dyno to tune it yet.
Se-Racer is offline   Reply With Quote
Old 01-02-2002, 08:44 PM   #3 (permalink)
Se-RiousRacer
was it hard to install????
Old 01-03-2002, 01:11 AM   #4 (permalink)
Se-Racer
very hard, it took us three days to figure out the 98 wiring diagram but after we figured it out it was easy to wire up.
Old 01-03-2002, 02:17 AM   #5 (permalink)
kjopi -sleeper-
i've got one in my 95....it was pretty fast to install...the wiring diagrams i had were a little confusing, but the voltmeter became my best friend...now it's running my GTIR turbo setup....works REALLY well too...i'll post a pic of it tomorrow....looks BITCHEN in the car
kjopi -sleeper- is offline   Reply With Quote
Old 01-03-2002, 11:26 AM   #6 (permalink)
kjopi -sleeper-
here ya go....my fancy interior...hehe
Old 01-03-2002, 01:26 PM   #7 (permalink)
Bwilsor
Secret Squirrel
Holy s---! that is a very nice setup you got there kjopi. What are the those switches for?
92 Black NX2K Hardtop, Hyperco2/AGX, and 15" K1's
Bwilsor is offline   Reply With Quote
Old 01-03-2002, 01:35 PM   #8 (permalink)
kjopi -sleeper-
the switches used to be for my NOS, but then i wanted some more power, so i went turbo....they're not doing anything right now, but they look fancy...the lights turn on when you activate the switch too...really fun to play with...i'm actually going to hook one switch up to a sylenoid so that i can regulate boost...it'll run 7lbs, and then 14 when the switch is on >:^D no clue what else to do with the others ***....i'm sure i'll think of something ***
Old 01-03-2002, 01:50 PM   #9 (permalink)
Se-Racer
Looks sweet, where did you get you gauge pod from i've been kinda looking for one.TIA
Old 01-03-2002, 01:55 PM   #10 (permalink)
Se-Racer
my ricey interior...
Old 01-03-2002, 02:46 PM   #11 (permalink)
kjopi -sleeper-
the pods on the pillar are just 300zx pods (they don't quite line up, but oh well) and the cup on the steering wheel is just an autometer cup with a nordskog digital oil pressure gague. you can get em all from summit. i got it on ebay for 5 bucks *** >:^P
Old 01-03-2002, 04:39 PM   #12 (permalink)
ATLANTICBLUE
Hey kjopi -sleeper- what kind of short shifter are you using?, looks pretty damn Short in that pic.
99 MAXIMA ES Sterling Mist 5spd
89 SUZUKI SWIFT 1.3GL 5spd
2000 Honda Civic SiR.
ATLANTICBLUE is offline   Reply With Quote
Old 01-03-2002, 06:25 PM   #13 (permalink)
kjopi -sleeper-
it's actually a stock shifter that has been slightly modified....the stock shifter has a plastic balljoint in it....we put it in a press and relocated the ball down about an inch or so...thus an instant shortshifter...it took about 2-3 inches out of the throw at the stock height, then i just chopped it off to make it shorter (i hated having that elephant dildo sticking up, i almost punched my LCD because of it)....so now i have a shortshifter with a REALLY short throw....when ppl drive my car i alwas get asked "is it in first or neutral?" it is VERY SHORT now.
Old 01-03-2002, 07:36 PM   #14 (permalink)
Mr_VVL
danm kjopi -sleeper- that interior is player pimp sh*t i must say man i like it clean set up keep it up
Mr_VVL is offline   Reply With Quote
Old 01-03-2002, 08:03 PM   #15 (permalink)
Se-RiousRacer
what kind of gains did you see with the afc???
Old 01-04-2002, 01:58 AM   #16 (permalink)
kjopi -sleeper-
i have yet to get it on a dyno....that should be by the end of the month, but it runs REALLY hard...i turned up the boost tonight...so it's running 10lbs now, and PLENTY of fuel to go around (i do have a bbk fuel pump, and 370cc injectors) i'm not sure about the HP, but it's enough to piss off a corvette >:^P i'll be sure to post more details after i get it on the dyno...i'm really curious myself
Old 01-04-2002, 02:30 PM   #17 (permalink)
Soopastank
Recovering Rice Boy
Quick Question
Kjopi,
Are you using the AFC along with the JWT ECU or are you using the AFC alone as your engine management?
GT28, 50lbs, 14psi daily driven
Soopastank is offline   Reply With Quote
Old 01-04-2002, 03:21 PM   #18 (permalink)
kjopi -sleeper-
i'm just using the afc for the fuel managemet...i wanted to see how well i could get the car to run without going JWT, and so far so good. it's a little tricky to get used to, but once you figure out the little tricks of the afc your set...it's really fast after that. i love it
Old 01-05-2002, 03:47 AM   #19 (permalink)
BoostedSleeper
kjopi, supposedly the SAFC has a corfrection program you can enable to fix the problem when using a blow off vlave that vents out tot he atmosphere. Have you experimented with that?
1995 200SX SE
Bluebird sr20det
13.9@102.9
BoostedSleeper is offline   Reply With Quote
Old 01-05-2002, 06:00 AM   #20 (permalink)
kjopi -sleeper-
no....not yet...i've heard of that as well, but my BOV is redirected back into my intake, so it'll prolly be a while until i mess with it
