for you guys who have done this how did you lay the urethane in the front motor mount the fluid type one, did you cut out some of the rubber to make pockits or just layed it in each side ?
Thanks
279 hp @ 17psi
Nx 2000 : It sticks to the road like bubble gum to hot asphalt
For all the mounts I took out all the inserted stuff, duct taped one side of it to hold the fluid in, and poured. You might think of something else besides duct tape to use- the stuff I had didn't do a terribly great job of holding the stuff in.
__________________ 99.5 Audi A4 Avant 2.8L quattro 5-speed 03 Honda Odyssey EX-L
Get 3M "Window Weld" Do one side and let it dry for a couple days then fill the other side. If you try to do the whole mount on one day the middle will never dry. We did this on a friends Eclipse and it worked wonders.
Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery.
--Winston Churchill
