Old 01-16-2002, 01:26 PM   #1 (permalink)
kpw97
SE-R-less
No 02???
How bad do you think it is to run without the 02 sensor. I couldn't get mine off and it's completely fouled. So, I've been running without it until I can bring it in. It'll just run rich right????
Kevin
01 Saturn SL1 (love that plastic in the city!)
Sold:
93 Classic w/ advanced timing, Stillen POP and Header
kpw97 is offline   Reply With Quote
Old 01-16-2002, 01:36 PM   #2 (permalink)
Nick
Stuck on an island
yeah you can still drive with a fouled o2 sensor but you will be running rich. but you can get idle hunting and flat spots in performance and some other symptoms. but i would try to get it fixed as soon as possible.
279 hp @ 17psi
Nx 2000 : It sticks to the road like bubble gum to hot asphalt
Nick is offline   Reply With Quote
Old 01-16-2002, 02:06 PM   #3 (permalink)
SmoothDaddyFig
NISSAN SOLDIER
bad bad bad!!!!!
Get it fixed fast.!!!
Treat your car right. The SR20 is a sensitive machine.
Jonathan
93 G20 "Im cruising tonight"
Old 01-16-2002, 03:55 PM   #4 (permalink)
Andy92RubyClassic
jo mom
are you hitting it with penetrating fluid every day.. just like brushing your teeth... don't give up..
- 92 SE-R white, ES mounts, HKS catback, Random Tech cat, Revolution wheels
-2001 G20 silver
Andy92RubyClassic is offline   Reply With Quote
Old 01-16-2002, 04:38 PM   #5 (permalink)
kpw97
SE-R-less
I've been hitting it with penetrating fluid each day. I don't know how good my mileage is, but my car seems to run MUCH stronger and smoother than it did with the O2 connected.
Old 01-17-2002, 07:55 AM   #6 (permalink)
Serban I am a moderator
I remember someone posted before that he put a spark plug in the place of the O2 sensor and got better milage. Anyone remember that?
'93 NX2000: SR20VE
Old 01-17-2002, 08:55 AM   #7 (permalink)
kpw97
SE-R-less
Yeah, that's what made me think of it. I was like, well, my car is probably running pretty lean, with poor mpg, and does not feel healthy. That guy had done it for awhile with no problem. So, why not run the car a little rich for a few days so as to not damage the motor. I think that guy was on the main list, IIRC.
Old 01-17-2002, 01:55 PM   #8 (permalink)
Bowlcut
pwnd
Well running rich isnt horrible for the motor, it is horrible for the cat ***. Its the fastest way to burn up a cat. So instead of trying to fix it for the 100 or so dollars for a new 02 or other issues that could be up, you end up spending that much or more on a new cat, and possibly multiple new cats. Not to mention the excess polution you are causing...while im not a tree hugger i dont see the point in defeating emssions equipment for no good reason. Plus I will garentee the car will run better if its in tune totaly
-Kevin
We are a community
Old 01-17-2002, 03:50 PM   #9 (permalink)
kpw97
SE-R-less
I'm by no means advocating doing this regularly. I'm just doing it untill I can get away from work to get everything fixed. I have a headbolt busted and need a new O2 (i think). So, why not run on standard fuel maps for a bit?
Old 01-18-2002, 12:38 PM   #10 (permalink)
Andy92RubyClassic
jo mom
get the o2 yet? you broke a header nut.. hope not the stud.. i've been spraying my back brake bolts and header bolts for a few days now.. then comes the propane torch and taps with the hammer... i will get them.. i am relentless.. for some reason the o2 turned real easily.. i used the special socket on my shortest wrench for that..
Old 01-18-2002, 01:43 PM   #11 (permalink)
kpw97
SE-R-less
I had broken a stud and left some in the block. I've decided that this may have contributed to my O2 problems. The car is going to get looked at in an hour or so. Hopefully I can get both done in one single swoop.
Old 01-21-2002, 12:17 PM   #12 (permalink)
kpw97
SE-R-less
On a side note, FWIW, I got 27 mpg on the mostly highway driving the other day. I'd say I put 30 miles worth of non highway. I guess that's decent. Doesn't compare to the 36 mpg I used to get with pretty much all highway. Although it was snowing on the way home, so I wasn't at a consistant speed all the time.
Old 01-22-2002, 12:57 AM   #13 (permalink)
FastNX
Professor Dingbat
Did you get that blasted head stud out? I did the same thing, and it's still stuck. A guy at work has this funky Blue Point tool for pulling out studs, but I'm so skeptical about drilling into my SR20. Persistent lubing and that tool plus some patince should do the trick, right?
Old 01-22-2002, 11:59 AM   #14 (permalink)
kpw97
SE-R-less
Well, the busted stud and O2 are getting fixed as we speak. The guy said they are removing the header, drilling out the bolt, and using a helicoil. Then they're gonna replace the gaskets because they're all burnt out. The O2 sensor will be replaced while the header is out of the car. Total comes to about $290
What could I say though? This needs to get done. I don't trust myself to do it and I'm so tired of my car running sh*tty. I want my old SR20 power back! Plus I still need to pass emissions Hopefully doing this and replacing the vacuum hoses will fix all of my problems. Let's all cross our fingers!!
Old 01-22-2002, 05:43 PM   #15 (permalink)
kpw97
SE-R-less
Ok, just got home after picking up the car. It definitely feels better. The mechanic showed me the old gasket. It was leaking in 5 places!! So, that's all taken care of. I still have the problem of the rpm's diving when I come to a stop. Time to address that problem next! I think it's a vacuum related problem. Although, my throttle response seems a little off, compared to how the car felt with the O2 disconnected. Maybe I'll reground my MAF while I'm playing car doctor.....
