Old 01-16-2002, 04:52 PM   #1 (permalink)
Car runs rough when it is cold?
Ok guys this is my dilema. When my car is cold it sputters a little bit. What I mean by this is that it is a little hesitant, but when the car comes up to temperature it runs awesome. I did a motor swap and my old motor did this as well. I believe it could be some kind of temp sensor. I have had this problem for over 2 years now and finnaly it is getting old to me. Its not that bad but everything else on my car works pretty well and finally I would like to get this fixed.
Do any of you guys have this problem and do you have any ideas on what this could be. And also is the part expensive?TIA
-Rob-
Get ready for a big SE-Rprise
Old 01-16-2002, 05:18 PM   #2 (permalink)
Off-Topic lurker..
I have this problem too, and HATE it.
The problem lies in 2 things:
Your Air Regulator Valve ($50 at nissan dealer)
Idle Air Assembly ($150 at nissan dealer)
those 2 items need to be either cleaned, or replaced.
my car doesent just sputter, it feels like it doesent want to be driven, but then, once the temperature needle moves up a little bit, she runs good. you can fix it yourself, probably, but i'm just going to buy new sh*t, *** i'm like that..
check out http://www.se-r.net/engine/cold_idle_fix.html
it tells everything about this gay ass problem that you and i have...
silversx is offline   Reply With Quote
Old 08-15-2005, 04:31 AM   #3 (permalink)
have the same problem, i just let it worm up. it's not that big a dieal to me. but he's right about those two things.. you might even see a performance increase out of cleaning/changing them. good luck....
SE-RiousRacer91 is offline   Reply With Quote
Old 08-15-2005, 07:57 AM   #4 (permalink)
Did you not realize this is over 3 years old?
http://phatboyaudioonline.com/
1993 NX2000-5SPD SWAP, 2120lbs. JDM Motor, Calumsult Realtime ECU, Brian Crower STG 3 cams, CP XTP 9.2:1 pistons, NX DP-100 shot, Prothane Mounts, ACT Xtreme/street disc, PR CAI with JWT POP, SSAC with 2.5" downpipe, Dynomax 3" muffler, Outlaw Intake Spacers, OEM wires with ngk plugs, UR Pulleys, Walbro 190, ST springs with KYB's, Xstatic Batcap, Axis maglites
Old 08-15-2005, 09:58 PM   #5 (permalink)
no, no i did not maybe if it's three years old it should be taken out or sumthing.....
