Old 01-17-2002, 03:27 PM   #1 (permalink)
TPS question
How do u get that little screw off that holds the TPS i tried to get it out but i couldnt do it. any suggestions.
93 se-r
dweed is offline   Reply With Quote
Old 01-18-2002, 07:41 PM   #2 (permalink)
NISSAN SOLDIER
WHAT SCREW?
Its just a plug. You squeeze it and pull it out.
Jonathan
93 G20 "Im cruising tonight"
Old 01-19-2002, 01:54 AM   #3 (permalink)
Like it or Don't Like it
you mean the screw on the back to move it back n foward?
NEO-VVL Got VT@K?
E²SR20.com
Digitek is offline   Reply With Quote
Old 01-19-2002, 08:13 AM   #4 (permalink)
bla bla bla
get your screwdriver on it, and tap it with a hammer while turning it. pita. I hate little screws
Old 01-19-2002, 05:55 PM   #5 (permalink)
the important thing for any screw is to use the correct size screwdriver. Also use a quality one. A lot of cheap screwdrivers don't have the correct geometry in the tip even if it is the correct size.
Dave
1991 SE-R 160K miles, OEM/ghetto SS, ES susp bshgs
1991 240SX - JWT ECU, 52K original miles!
1992 Geo Metro, 204K miles, orig clutch, GTI sway bars
2001 PT Cruiser- Taupe limited 5spd
Probedude is offline   Reply With Quote
