Old 01-19-2002, 04:15 PM   #1 (permalink)
Da91NX
Now Turbo RWD!!!
knob n boot
hey i got the factory shifter knob abd rubber boot and i wanna get rid of them. i got a new boot n knob put on and the knob wont come off.
Da91NX is offline   Reply With Quote
Old 01-19-2002, 04:25 PM   #2 (permalink)
silversx
Off-Topic lurker..
try covering it with a rag and using vice grips to loosen it..
silversx is offline   Reply With Quote
Old 01-19-2002, 04:26 PM   #3 (permalink)
Stiletto
SEL Master
have you tried wrapping a towel around the knob and then clamping down w/ vice grips? most people get it off that way. but if you have a replacement for the knob, then skip the towel part.
http://members.cox.net/sr20-sel/sel-badge.jpg
99 Sentra SEL.
To understand the raw power of SEL, click on the badge.
Stiletto is offline   Reply With Quote
Old 01-19-2002, 04:37 PM   #4 (permalink)
Bowlcut
pwnd
since he has the stock plastic knobs some NXen came with id just rip it off any way possible. Id take some vice grips lock down on it then take a rubber mallet and hit the end of it, mini impact wrench. Its both screwed on and glued on. only thing ive ever wondered about is could you damage the shift linkage by all this leveraging. the other popular way is to take out the shifter put it on the ground put it under the wheel of the car and wrench it off that way. but i dont think you care about the condition of the knob, se-r people want to keep the leather knob in good shape usualy.
-Kevin
We are a community
Old 01-20-2002, 08:30 PM   #5 (permalink)
SENTRASER
Drive it like ya stole it
SENTRASER's Avatar
Trader Rating: 33 (100%)
You just gotta have monster grip hands like I do....:p
~Ryan
1992 NX2000 Hardtop
1989 B12 AWD wagon
Originally Posted by chriscar
Old 01-21-2002, 09:28 AM   #6 (permalink)
bensa
Good Luck.... I had to peel mine like a banana, cut the rubber bits and then took a wrench to remove the nut in the end... I still have to cut the shifter so I can use my Momo Shift boot!
bensa is offline   Reply With Quote
Old 01-21-2002, 09:49 AM   #7 (permalink)
SE-Rican
What he said. It works everytime
-Rob-
Get ready for a big SE-Rprise
Old 01-21-2002, 02:03 PM   #8 (permalink)
Stiletto
SEL Master
i wouldn't say that...i had to rip mine to pieces. i had the BIGGEST vice grips you have ever seen, too. that damn cement nissan uses is strong.
Old 01-24-2002, 01:22 AM   #9 (permalink)
sleeping 91ser
boosting
I just took mine off with my hands, It was probably allready taking off before I got the car though.
Sean
sleeping 91ser is offline   Reply With Quote
