Hi to all , im in the moment to ask questions itīs my first rebuild and i want to go turbo, to have like 300-350 hp, it will be good idea to rebuild a 0.020 crank shaft bearings-0.020 rod bearings, and how much i can make the bore bigger,example vg30 pistons do i have to resleve the block?
Ok that was my nephew joking around, i found the SDS of the vg30dett and the diameter of the piston grade 1 is 86.975 to 86.985 mm and the block should be bore from to 86.995 to 87.015 using clearance of the sr20 engine from 0.010 to 0.030, what about the head gasket 87mm? any vendor? it should be good on boost?
