Originally Posted by $pider
I need to remove everything on the passenger side of the motor like.. the crank pulley, chain cover and stuff like that to clear the way of the chain or there is an another way ?
I tried to lift the head.... but the chain block it in place.
Help me out plz
If you're just trying to get the cylinder head off then you don't need to remove the timing chain... I am assuming that the motor is still in the car?
Just remove the sprockets and just keep tension on the chain as you remove the cylinder head. It takes two people but can easily be done... here's proof
Edit - Oh yeah, and remove the tensioner as mentioned above.
