Old 06-07-2005, 12:25 AM   #1 (permalink)
Flywheel torque specs
Hey, I would just like to know how many lbs you got to torque your flywheel bolts to.
dansr20 is offline   Reply With Quote
Old 06-07-2005, 12:32 AM   #2 (permalink)
from my expierence.. dont even bother... the first swap i ever did, i had torqued the flywheel bolts to the fsm's specs, with a calibrated tq wrench...a week later, five of them came loose and costed me a motor. from then on i use some loctite and tighten them with a breaker bar. but that was just my expierence.
THE VE-T IS ALIVE.
-92 sentra vvl-t 470whp...385tq. 24lbs.
-98 sentra SE/ sr2ve powered.
-2005 c230 kompressor.
-2006 Lancer Evolution 9 MR.
http://images.cardomain.com/member_i...66_28_full.jpg
your local asshole.
LanceSR20 is offline   Reply With Quote
Old 06-07-2005, 02:24 AM   #3 (permalink)
I did 70lbs on them and never had a problem.
Phxdude is offline   Reply With Quote
Old 06-07-2005, 02:50 AM   #4 (permalink)
Honda Employee...
from my 1991 FSM: 83-93 N-m (61-69 ft-lbs) for the flywheel to the block.
-Zack
-'91 SE-R, Aztec Red: JWT Pop-Charger, Fidanza Flywheel, JWT PP w/01 SE disc. AGXs w/GC coilovers (300/279) & C/C plates. NX2K Brakes w/Carbotech pads & Crown SS lines. Progress rear sway bar. Active Tuning RSTB, ES Bushings & motor mounts.
gottabfast is offline   Reply With Quote
