This is the first B13 I've owned. The piping is 2.25". Not sure about the tune up, but I'm going to take care of that in a few days. As far as the car being slower, it simply isn't as fast. Before this problem, the car was quick. Now it's surprisingly slow, and it doesn't respond much to the press of the gas pedal. It's hard to describe, but whatever gear you're in, when you're at a steady speed and then press the gas down a little farther to speed up, the car should respond . Mine doesn't seem to since this problem occured. Doesn't matter how far down you press the gas, it barely responds.
