Old 01-20-2002, 11:12 AM   #1 (permalink)
Army Boosted
Oil Pressure gauge question....
Well yesterday we installed my boost gauge, rich/lean gauge, and oil press. gauge. The boost and rich/lean work fine, but the damm oil press. gauge reads like 10 and doesn't move any higher or lower. They told me it's because there's air in the line so i need to give it a few days for it to bleed out. please help a confused SE-R driver thanks.
First, Big Turboed 1995 200sx SE-R
then, KA-T powered 1997 240sx SE
now, EVO IX with GT37R turbo.
SE-Rious B14 is offline   Reply With Quote
Old 01-21-2002, 06:45 PM   #2 (permalink)
Air shouldn't be a problem. In fact for mechanical gauges it is a plus since it smooths the pulses coming from the oil pump.
What type of gauge do you have? electrical or mechanical.
(This is why I like mechanical gauges, not much to go wrong).
Dave
1991 SE-R 160K miles, OEM/ghetto SS, ES susp bshgs
1991 240SX - JWT ECU, 52K original miles!
1992 Geo Metro, 204K miles, orig clutch, GTI sway bars
2001 PT Cruiser- Taupe limited 5spd
Probedude is offline   Reply With Quote
Old 01-22-2002, 12:39 AM   #3 (permalink)
Trader Rating: 102 (100%)
Well, most likely he has a mechanical one since he thinks air is in the line. And there are many things that can go wrong with a mechanical one, leaking oil inside the car for example.
Good example, I helped a friend of mine install one in his turbo G20, I was under the car putting the sender and the tubing in the block, and he was attaching the tubing to the gauge inside the car. He mounts the gauges, and turns the car on, and is getting a very low reading, I ask him if he tighened it good, he says yeah.
We take the gauge out, he had a plate made right over his radio for 3 gauges...and of course he didnt tighten it good, and oil leaked all over his radio.
Serban is online now   Reply With Quote
Old 01-23-2002, 02:23 PM   #4 (permalink)
Of Topic Count: 11,684
thats no fun
God Bless America<><
D e n n i s ..aKa.. D - N y c e
Ncat
Even though you can't see him, GOD is always there O:-)
99 Mercedes S500
99 Mazda 626
xDennis is offline   Reply With Quote
