Old 06-09-2005, 12:44 AM   #1 (permalink)
Crown Brake Line Install
Hey fellas. I'm going to try to install crown brake lines in the next two days. I've searched this topic but I've come across some posts from members that notice fitment issues on the brake lines. This is a huge bummer after you spend 120 bucks on brake lines. So before I open the package. What should I look out for when Installing these lines?
If any of you guys have comments on these lines good or bad, then please post. Thanks.
This is going on a b13, no abs, agx struts.
Old 06-09-2005, 01:13 AM   #2 (permalink)
Original Owner
aztecred92's Avatar
I've got Crown brake lines on my SE-R and didn't have any serious fitment issues. The only problem I'm aware of and experienced myself was with the spring retaining clips that hold the lines secure to the strut housing. A couple of tweaks with some pliers and the issue was solved.
aztecred92
L I V E S T R O N G
'92 SE-R
'85 MR2
aztecred92 is offline   Reply With Quote
Old 06-09-2005, 01:07 PM   #4 (permalink)
Trader Rating: 17 (100%)
note: use a 10mm FLARE NUT wrench not a regualar one, i wish i knew that i would not have stripped the hell out of the brake lines.
Oh well you live and you learn.
trini
Car shopping made easy! We do the work for you while you save time, money, and hassles! Visit us at Personal auto brokers.com
Karting Vist............www.Torontokartstands.com
trinispeed is offline   Reply With Quote
