Old 06-09-2005, 07:19 PM   #1 (permalink)
Trader Rating: 7 (89%)
worst case senario
well as stupid as this sounds my car isn't moving thanks to a 4 inch piece of coolant hose that is physicly impossible to replace. Last night i was getting on it and next thing i know i see some smoke comin from under the hood. Well i take a look and see that the 4 inch long piece of coolant hose that is directly below the intake manifold ( on a u13bb) has a split and is leaking pretty good. I think no big deal easy fix. Well i get the car home and go to work on it this morning well after about 3 1/2 hours i finally get the old hose off. And to make a long story short for the past 7 hours
have been spent lying under my car with my head in a puddle of collant in 90 degree weather trying to get the new line on which is impossible as far as i'm concerened with the motor in the car. Anyone else ever had to replace this? any suggestions would be appreciated i a way words can not express. thanks
yingtiry is offline   Reply With Quote
Old 06-09-2005, 07:36 PM   #2 (permalink)
Monkey Power
I had to replace mine but the motor was on the stand when I changed it. It can be replace with the motor in the car. You can help your self out by making the house plyable by soaking it in some hot water. this will allow you to work with the hose a little easier. You may want to remove some items for extra work space.
94 se-r 342whp 289lbft @ 15psi
92 se-r sr20ve with N1 cams
http://www.cardomain.com/id/cortrim1
www.southern-shift.com
cortrim1 is offline   Reply With Quote
Old 06-09-2005, 07:44 PM   #3 (permalink)
never herd of this hot water idea any idea on how long to soak it. I was honestly thinking of also lubing the hose and outlets on the motor with something like ky no joke.
Old 06-09-2005, 08:42 PM   #4 (permalink)
No soup for you
Trader Rating: 30 (100%)
That will help. In seven hours you could have removed the IM and reinstalled it. Just my opinion.
John
B12 turbo madness
424 whp / 328 ft. lbs
2440 lbs. w/ a full tank
B14 VE Hotness
244 whp / 228 ft. lbs
Old 06-09-2005, 11:46 PM   #5 (permalink)
yeah i could have but i dont have a new gasket so i'de be f'ed if i did. when you say hot water do you mean like boiling hot or just hot out the tap.
Old 06-10-2005, 12:06 AM   #6 (permalink)
The Boost Bear..Rawr!
Zexel's Avatar
Trader Rating: 42 (98%)
Just hot tap water will make it slightly more plyable. His idea will work. And I replaced mine as well, on a motor stand. I would double up the hose clamps, just so you know it won't leak again.
And I'm with John, I would just take the Intake Manifold off, it will be tons easier.
Corey
Zexel is offline   Reply With Quote
Old 06-10-2005, 05:35 AM   #7 (permalink)
oh so LAZY
Will's Avatar
lube it up inside the ends of the hose to get it on, it will make you life much much easier. I would have taken the mannifold off, and probably reused the same gasket.
Click for My Car Pics
White '92 NX2000 All Stock.
Will is offline   Reply With Quote
Old 06-10-2005, 12:40 PM   #8 (permalink)
I was just worried that the gasket may rip apart when i remove the manifold but that may be what i am going to have 2 do
