Old 06-10-2005, 03:52 AM   #1 (permalink)
A few questions regarding belt driven accessory removal....
After looking at some pictures on this forum and seeing an "Axle Driven ALternator" posted in another thread I got to thinking......
If you were to Replace the Water pump with an electric unit, remove AC and PS pumps, and find a way to drive the alternator off of the flywheel and use Deep cycle batteries to hold current charge, could you run an engine completely beltless?
Considering the savings in static loss of energy, wouldnt the ability to weigh and balance the engine for very high revving be pretty attainable via weighting the crank via the pulley and flywheel?
Sorry if this sounds to you, Im just pondering
BObby12many is offline   Reply With Quote
Old 06-10-2005, 05:32 AM   #2 (permalink)
oh so LAZY
Will's Avatar
I have liked the idea of a beltless motor for some time. Where did you read the thread about an axle driven alternator?
Click for My Car Pics
White '92 NX2000 All Stock.
Will is offline   Reply With Quote
Old 06-10-2005, 05:48 AM   #3 (permalink)
I didnt read anything about it... only saw a pic in this thread of a racecar using this setup.
http://www.sr20forum.com/members-rides/118613-new-valverde-racing-team-race-monster-56k-keep-away.html
Old 06-10-2005, 05:59 AM   #4 (permalink)
oh so LAZY
Will's Avatar
interesting, very interesting. Im sure it could be done, but its hardly worth it.
Interesting also because the speed of the alternator would vary with speed not RPM, so if it is stopped... there is no amperage.
Old 06-10-2005, 02:10 PM   #5 (permalink)
SE-R Geek / Nissan Tech
yeah but it's a racecar, too....probably enough in the batteries for pit stops and such. not very streetable
92 SE-R Autocrosser.... too much to list
Old 06-10-2005, 02:33 PM   #6 (permalink)
Not interested in this as a street setup....
I just thought it was a very trick setup, and it lest the mind wonder about possibilities alot of us never though of.
