Old 06-10-2005, 02:55 PM   #1 (permalink)
Charlie Brown look alike
Trader Rating: 23 (100%)
How do I bleed my brakes by myself without having speedbleeders?
I did a seach online and found this but I don't know if I really agree with it. What does anyone think?
Here is the link:
http://www.diynetwork.com/diy/ab_bra...531840,00.html
Peanuthead is offline   Reply With Quote
Old 06-10-2005, 03:06 PM   #2 (permalink)
EECS Nerd.
Apparently, Mirage uses the auto-zone DIY kit.
http://www.sr20forum.com/showthread....ble ed+brakes
Old 06-10-2005, 03:08 PM   #3 (permalink)
Set Verbose On
You probably already know this, but just in case, the bleed order on our cars isn't standard, and doesn't follow the "farthest from MC first" pattern. Make sure you get the right bleed order before you go forward with it.
For what it's worth, I managed to bleed mine alone without speed bleeders on the rears. I used pretty much the technique (with a tube, but no other "kit") they describe here, except I ran through (much) more than "a few seconds" of fluid w/out bubbles. I used a cinder block to hold down the brake pedal when it was time to close the bleeder. The pedal feel is great (nx brake upgrade), but it took longer than it would have with an assistant.
1991 SE-r Aztec Red "Quiet, She's sleeping"
1992 SE-r Ruby Red "Now with 100% less engine"
1992 SE-r Black Beauty... "It's not his anymore"
Bearjing is offline   Reply With Quote
Old 06-10-2005, 03:10 PM   #4 (permalink)
SR powered S13 coupe
McCoy's Avatar
Trader Rating: 74 (100%)
My friend purchased this power bleeder and it has worked quit well for both his Sti and my sentra It worked best to also purchase the cap that screws onto the MC over there generic cap that you have to use two small chains to get the pressure fit.
Old 06-10-2005, 07:49 PM   #5 (permalink)
Import Tech.
Dang , the best way to bleed the brakes is the other one person method , basicly get a bottle about 1/4 full of brake fluid , use a length of vacuum hose , put one end in the fluid , one on the bleader, open bleader, then slowly pump the brake pedal 10 times to the floor , then close the bleader, remove hose, do all 4 wheels, again starting from firthest from the Master ..... Be sure to check the fluid level between each wheel ....and be sure the other end of the hose stays in the brake fluid .....
SHAWN
Ger-Brock Performance
Portland OR.
'98 Sentra SE.. Time Attack
'06 Pathfinder SE
'93 Infiniti G20 5spd.
My Nissan Site !!
Old 06-10-2005, 09:05 PM   #7 (permalink)
Dreamin' of VVL
I use that same Motive pressure bleeder on all my cars and it works awesome. I agree though, getting the adapter that fits our reservoir is the way to go. The one it comes with with the chain and clips sucks ass.
johnand is offline   Reply With Quote
Old 06-10-2005, 09:09 PM   #8 (permalink)
McCoy's Avatar
Yeah... learned that one when we spilled about a pint of brake fluid into the engine bay due to the cheap one loosing it's seal
Old 06-10-2005, 10:47 PM   #9 (permalink)
Dreamin' of VVL
Yep, been there done that
