It could be an injector, headgasket leak, intake manifold gasket leak.
To check the injector, it's easy, just use a voltmeter and ohm out the injector.
To check the intake manifold gasket, let the car idle and spray carb cleaner around where the gasket is and see if the idle comes up/smoothes out. This is the gasket between the manifold and head.
93 NX2000 VE
08 Frontier Se
