Strange squeal from 1,000 to 2,000 RPMS. - Page 2 - SR20 Forum
Old 06-26-2005, 03:56 AM   #21 (permalink)
B13 Newbie
I would just hate to go through all the work, and then find out it's not the WP.
sgtiger is offline   Reply With Quote
Old 06-26-2005, 05:47 AM   #22 (permalink)
Drive it like ya stole it
SENTRASER's Avatar
Feedback Score: 34 reviews
Well, you've gone through the process of elimination; although you need to pick up a stehescope and put it on the water pump while the car is running and make sure its coming from that, and not the powersteering pump.
Something like this would work:
http://www.harborfreight.com/cpi/cta...emnumber=41966
~Ryan
1992 NX2000 Hardtop
1989 B12 AWD wagon
Originally Posted by chriscar
Old 06-26-2005, 11:38 AM   #23 (permalink)
B13 Newbie
Oh wow, good find on the cheap price! Thanks!
Old 06-26-2005, 02:19 PM   #24 (permalink)
toolongtuning
is it a low squel or a chirp
sh1ft is offline   Reply With Quote
Old 06-26-2005, 02:33 PM   #25 (permalink)
B13 Newbie
squeal.. happens at idle after the engine warms up and decel from 2-1k rpms.
Old 06-26-2005, 02:59 PM   #26 (permalink)
Is an SE-R/VE a VE-R?
The pin stethoscope from HF is okay for mechanical noises and you should be able to find your noise with it, but I after all these years I still prefer an air source stethoscope - sometimes you can rig something like the HF $6 special with a piece of tubing (replace the pin with the tubing so you have a direct air path from the end of the tubing to your ears) so you're HEARING the noise rather than having the pin pick up metal vibration. As the man said, can't get along without tubing for vacuum leaks.
Old 06-29-2005, 08:49 AM   #27 (permalink)
Are you sure you sufficiently tightened the belt?
MaxPwr is offline   Reply With Quote
Old 06-29-2005, 11:11 AM   #28 (permalink)
B13 Newbie
The mechanical scope didn't tell me anything. And yes, I definitely tightened the belt (old and new). Hell, I even tried some belt dressing on it. Nothing is slipping.
Old 06-29-2005, 05:26 PM   #29 (permalink)
SENTRASER's Avatar
Water pump. I bet its the bearings. How may miles has the car got on it? While you're changing the water pump out, why not throw some UR pullys at it? Just an idea.
Old 06-30-2005, 03:17 AM   #30 (permalink)
B13 Newbie
Car has 126k miles on it. It's the original WP. Mainly it's an issue of finding the time to do the job. Why do you think the bearing only sounds off between 1-2k rpms?
About the UR, I have a lightened pulley on my Spec-V, didn't seem to do much. Do they really work well for the SR20?
Old 07-01-2005, 06:11 PM   #31 (permalink)
SENTRASER's Avatar
The water pump pully stops caviataion of the water pump at higher RPMS (the water pump no longer circulates). Its a good upgrade "while you're in there".
Old 08-15-2005, 03:13 AM   #32 (permalink)
replace the belts, sounds like it might be that simple. or the water pump thing... hope for just replacing the belts. though.. good luck....
SE-RiousRacer91 is offline   Reply With Quote
Old 08-15-2005, 11:13 AM   #33 (permalink)
B13 Newbie
both belts were replaced, squeal still exists. I actually just did a 1500 mile roadtrip. The squealing is a little louder now (128k miles), and can be heard at 2200rpms now. I suppose it's just a timebomb.
Old 12-20-2010, 06:29 PM   #34 (permalink)
Is that wrong??
vqman's Avatar
Feedback Score: 20 reviews
blast from past thread - I have a similar problem right now, above idle the squealing is loud, I'm thinking water pump.. but i have no leaks as of yet.
I wish I had more time between now and Christmas, my next weekend is Christmas.. ugh. I still need to do shopping.. FML
1991 | black | SE-R
bridgestone potenza RE-11's | hypercoil gen ii springs | shortened koni struts | ST front sway bar | octotat 3 point RSTB | octotat 2 point FSTB | ad22vf calipers | carbotech pads | sr20ve | n1 cams | jk nemu rt | hotshot cai | ssac header | 2.5" mandrel bent exhaust | wrx STi muffler | jwt motor mounts |
SR20DEEP MidWest Chapter
vqman is offline   Reply With Quote
Old 12-20-2010, 07:27 PM   #35 (permalink)
SENTRASER's Avatar
Hmmmm....what about the alternator you just installed?
Old 12-20-2010, 07:35 PM   #36 (permalink)
Is that wrong??
vqman's Avatar
i guess it COULD be that.. but hell i dunno.. i don't want to f*ck with it right now.. but I guess I'm going to have to
