a friend called me up and told me *** he installed a MSD 6AL to his 96 sentra se and its not working rite and the engine lite came on.
so i checked it out and found out that he wired it up wrong then i rewire it again and buy a new set of dist. cap.
the car is running but he has a check engine lite on and sometimes it hesitate on low rpm.
pls. help me out
do you have the proper rev limiter module in there? di you pull the bsttery csble for at least a half hour to see if the engine light would reset? did you swap the coil also?...stock coils usually dont do so good w/ msd....recommend any of the blaster coils or the ss!
