Old 01-25-2002, 08:03 AM   #1 (permalink)
MauiBlueGride
Seth's Dad
Jwt Ecu - Helppppp!!!!!
Ok here is the situation,
Can I get a 1.6L ecu reprogrammed to work with a blue bird DET and the standard sr20de sensors?
I swear my old ecu (I sold cause I was ***** install it in my nx instead of my 200sx) said on the bill it was a 1.6 core....
Anyways JWT told me they can't do 97 and 98 ecus - I was like huh? I know they can't do 98's but 97?
Also - they said they can reprogram the ecu but Ihave to use the 1.6L sensors (02, temp, and no more knock sensor).
Does that make sense or was my guy smoking something?
Thanks
Chris
2002 G20 Sport - Silver
2003 Olds Mini-Van - say wha????
1997 Corolla - 200+k!!! - Wifeys
MauiBlueGride is offline   Reply With Quote
Old 01-25-2002, 08:21 AM   #2 (permalink)
kpw97
SE-R-less
They definitely can reprogram 97 ecu's. Something is up there. As for the other stuff. I'm stumped! At first glance I'd say no. But, that is just a guess
Kevin
01 Saturn SL1 (love that plastic in the city!)
Sold:
93 Classic w/ advanced timing, Stillen POP and Header
kpw97 is offline   Reply With Quote
Old 01-25-2002, 11:08 AM   #3 (permalink)
Saaby
Living up Boost
That makes complete sense. You would have to use the GA16DE sensors since its a GA16DE ecu that you are trying to reprogram. I would get an SR20DE ECU if money was not an issue and have that reprogrammed. Also, the years they are talking about relate to the GA16DE ecu and not the SR20DE ecu. They can reprogram ecu's from 91-97 for the SR20DE.
-saaby
Saaby is offline   Reply With Quote
