Old 01-27-2002, 01:02 PM   #1 (permalink)
MauiBlueGride
Seth's Dad
Netural Pos. Switch
Anyone have experience with the netural pos. switch on a 5spd? I'm looking at the FSM and it looks like it could be the cause of why my cruise isn't working - it appears that it should goto ground when not in gear - but its not that detailed - also anyone know the cost to replace it - mine isn't showing anything.
Also - can someone cofirm that on a 5spd if you pop it out of gear while on cruise does that kill the cruise?
Thanks
chris
2002 G20 Sport - Silver
2003 Olds Mini-Van - say wha????
1997 Corolla - 200+k!!! - Wifeys
MauiBlueGride is offline   Reply With Quote
Old 01-28-2002, 08:30 AM   #2 (permalink)
kpw97
SE-R-less
It might be the cause. My cruise just stopped working. And I know it's not the fuses. Does the cruise control light come on to say it's ON? It should fully come out when your foot is off the pedal. If not, you need to readjust it. Did you ever adjust your brake pedal? Adjusting that too low can have the same effect.
If you pop out of gear, the cruise should disengage. That is my understanding at least.
Kevin
01 Saturn SL1 (love that plastic in the city!)
Sold:
93 Classic w/ advanced timing, Stillen POP and Header
kpw97 is offline   Reply With Quote
Old 01-28-2002, 10:14 AM   #3 (permalink)
MauiBlueGride
Seth's Dad
Ok thanks - my light comes on (the green light at the switch) and I can hear relays when I hit the button but nothing after that.....
Chris
