Old 07-24-2005, 03:25 PM   #1 (permalink)
KEY NISSAN EMPLOYEE
Help, EGR bolt frozen and round'd!
Ok so as i was attempting to put my header on i realized that the EGR was completely frozen to the manifold. I've tried everything, PB blaster, 24 mm wrench, adj wrench, vise grips, hammer, heat, even Coke for Gods sake! so thanks to all my attempt the top of the bolt is round'd now. Ok so heres what i was wondering, i have a a US SR20, and i know that the JDM SR's don't have EGR, my question is.... can i cut off my EGR tube and block the intake side and plug the EGR port in the header? Will this work? Will the ECU go into limp mode? please let me know.
PROJECT LUCY: 10 psi of fun
I'm more JDM than you, deal with it.
MySpace
MOTORDYNE and STILLEN Dealer let us earn your business!
prince nismo is offline   Reply With Quote
Old 07-24-2005, 04:58 PM   #2 (permalink)
yes you can.......and if the check light does come on, put a 100ohm resister on the egr sensor....i think its 100ohm, you will not go into limp mode
CUSTOM MADE!
for sale:
side exit exhaust!,
gauges.......2 clusters
92-SENTRA SE-R i miss my sentra!
PROJECT 510
KA24DE.......SOON TO BE TURBO!
gun_metalz is offline   Reply With Quote
Old 07-24-2005, 04:59 PM   #3 (permalink)
www.FAIRTAX.org
paNX2K&SE-R's Avatar
Trader Rating: 66 (100%)
What kind of heat did you try? A little prop torch? You should take it to a muffler shop and give them $5 to really heat up up like glowing red with an oxy/acet torch. After it cools down try some vice grips again after PBing it.
91 SE-R w/DET
02 G20 Sport 5spd
94 Miata "homobile"
93 240SX Family Project
Old 07-24-2005, 05:33 PM   #4 (permalink)
200 whp club
Man i think u and i were having the same Bi#$h ass problem. Yersterday i was putting on my Headers too and i run into the same problem. I ended up taking off the other end of the EGR along with the stock header. When the stock header was off i got the EGR off. It was a B$%^h bro. Just unsrew the other end of the EGR and u should be fine
Damien
B15 SE
B13 SE-R
dmp316 is offline   Reply With Quote
Old 07-24-2005, 06:38 PM   #5 (permalink)
KEY NISSAN EMPLOYEE
Thanks for the advice guys... i am having a problem getting to the other end ***... should i just disconnect all the vac hose's and get to work and suck it up.?
Old 07-24-2005, 08:56 PM   #6 (permalink)
200 whp club
i had to also take my intake apart to get to the othe end of the EGR, just remember where all the hoses go
