Disable knock sensor? - SR20 Forum
Old 09-05-2005, 05:57 AM   #1 (permalink)
Ok, bassicly I have been getting code 34 which we all know is Knock sensor, for a while. I replaced the sensor and after numerous ECU resets its still giving me the code. Can I simply unplug it or is there anyway to run the car without a knock sensor so the car just 'pressumes' there is no knock?
Yes ive searched.
RWD Nissan Primera / G20
krazeguy.com
New Zealand Primera Car Club
krazeguy is offline   Reply With Quote
Old 09-05-2005, 09:05 AM   #2 (permalink)
The Boost Bear..Rawr!
Zexel's Avatar
Feedback Score: 46 reviews
IIRC, it won't work. Sure, you can unplug it, but you'll cars timing will be 'retarded' the whole time. When your vehicle assumes knock, your timing retards itself. So, it may work, but I doubt it.
Also, somewhat adding, trying not to hi-jack, but I accidentally snipped my knock sensor wire. I soldered it back together, but instead of running the ground wire to my ECU, I just ran a chassis/block mounted ground wire. This ok?
Corey
Zexel is offline   Reply With Quote
Old 09-05-2005, 02:16 PM   #3 (permalink)
pulsar gti-r owner
as far as i'm aware the ecu needs to see a signal from the knock sensor to operate properly. The fault may not be with the actual sensor, it could be the connector or harness or ecu but would still show 3.4
Kieron is offline   Reply With Quote
Old 09-05-2005, 04:07 PM   #4 (permalink)
Hmm, can someone tell me the resistance of the stock sensor?
Old 09-05-2005, 04:32 PM   #5 (permalink)
You need to torque a bolt/nut on the sensor. 30Nm of torque for the ecu to "see" everything is in check. Don't forget to ground the nut/bolt setup to the engine and tierap it to a power cable or heater hose.
presto: 0 knock, 0 retard
Midnight Blue 97 Primera SRI, UK blacktop SR20DE & ECU, Apex'i SAFC-II, RSM-GP & G-sensor, Hotshot C.A.I., ETCC spec TB, SSautocrime header(wrapped), JWT S3R, Walbro 255, Nismo AFPR, Magnecor KV85,, Jun U LW FW, B&M SS, Eibach springs, Koni Adj. shocks, Innovate LMA-2.
stoney78 is offline   Reply With Quote
Old 09-05-2005, 04:40 PM   #6 (permalink)
If im testing the knock sensor ECU side, should I check it at pin 27 on the ECU and what should it read?
Old 09-05-2005, 05:00 PM   #7 (permalink)
AWD owns me
Jaketips42's Avatar
Feedback Score: 12 reviews
Why would you want to rid of your knock sensor. He's a little helper.
Sporting the GC awaiting EJ20T
____________________________________GC Pilot
Subaru stole me from Nissan
Old 09-05-2005, 07:33 PM   #8 (permalink)
retired
Feedback Score: 9 reviews
JWT programs their ecus to not look at the knock sensor. (random bit of information)
Old 09-05-2005, 09:09 PM   #9 (permalink)
I want to disable it because I simply don't think its THAT usefull for me. So long as my timing is correctly set.
Old 04-09-2011, 10:23 AM   #10 (permalink)
i want to get this phormula knock guage installed and the stock location is best so... but if my retuned ecu doesn't read it then i think i could just relocate it maybe?
pimp02si is offline   Reply With Quote
Old 05-26-2011, 09:51 AM   #11 (permalink)
KNOCK
SURE U CAN ITS GREAT IF U HAVE SOME SORT OF KNOCK DETECTION
VE+T 30R
Skunk is offline   Reply With Quote
