car dies when warm, cant restart unless cold - SR20 Forum
post #1 of 12 (permalink) Old 09-23-2005, 04:38 AM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
started happening just yesterday... prior to that the car was running fine minus a small vacuum leak (vacuums oscillated around 18-20). changed spark plugs (which were pretty black on the threads), didn't solve it. here's what i noticed:
- car starts when engine is cold
- when it warms up to normal operating temp, it will just cut off like u just turned the ignition to off
- trying to start it right after, the car cranks but it doesnt start up. if i leave it alone for 5-10 min, it will start up but i wont get more than a few feet until it shuts off again.
- if i let it cool off for a few hrs, i can drive it for about 10 min or until it warms up again, at which pt it shuts off again
i'm gonna prob pull the codes 2mrw, but anyone have ne ideas? this is on a w10 avenir.
nissan_dude is offline
post #2 of 12 (permalink) Old 09-24-2005, 06:11 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
pulled the codes, camshaft positioning sensor (0101) and ignition signal (0201)..
harness tested out fine, so looks like i gotta replace the distributor..
post #3 of 12 (permalink) Old 04-28-2008, 05:28 AM
SE-ROLGIST
Quoted: 0 Post(s)
Feedback Score: 14 reviews
Im having the same problem after installing the msd 6 in my car. Any other solutions to this problem?
topdog781 is offline
post #4 of 12 (permalink) Old 04-28-2008, 08:28 AM
Quoted: 0 Post(s)
Electrical problem in the ingition system. This happens to honda and acura alot. It usually is the main relay. The relay gets hot, the pins inside the relay seperate, voltage stops, engine stalls. Relays gets cool, pins close back up, car starts.
Not sure if nissans have a main relay, but check that too.
NissanSpeed01 is offline
post #5 of 12 (permalink) Old 04-28-2008, 12:03 PM
SR20DEviant
Quoted: 0 Post(s)
Feedback Score: 30 reviews
I had the exact same issue. I had it die on the highway a couple time snad had to wait like 20 mins for it to cool down before it would start again. It's the coil.
Originally Posted by Serban View Post
'92 NX2000VE - SR16's, BC S&R's, Hot Shot intake w/ pop, SSAC header, 2000 SE disc, ACT HD PP, TWM shifter, FSTB & RSTB, AGX's for now, CSK's+RM's on the way, Prothane MM
'91 SE-R For Sale: http://www.sr20forum.com/cars-sale/2...ots-parts.html
PhorB13 is offline
post #6 of 12 (permalink) Old 04-28-2008, 01:55 PM
KASSANOVA!!!
Quoted: 0 Post(s)
Feedback Score: 47 reviews
my auto p10, had similar problems. car would start up fine in the morning, but won't start again after its up to temperature. mine turned out to be the coolant temperature sensor. that fixed it.
92 Dark Gray Sentra SER
92 Red Sentra SER
bobbyisking is offline
post #7 of 12 (permalink) Old 04-28-2008, 03:39 PM
Quoted: 0 Post(s)
Feedback Score: 3 reviews
X2 on the 2 wire coolant temp sensor, you're car is flooding because the ecu is getting the wrong reading from that sensor. It's like 15 bucks. 2 WIRE.
-2002 WRX Wagon.
-2003.5 Mazdaspeed Protege.
-1995 200sx SE-R.
-1993 Classic SE-R.
-1991 NX2000.
-1987 FC3S TII.
-1993 NX2000.
-1991 NX2000.
-1992 240sx.
hondaeat-r is offline
post #8 of 12 (permalink) Old 05-03-2008, 04:52 PM
SR20DEviant
Quoted: 0 Post(s)
I'm still leaning towards the coil bro. You can get a used coil for hardly anything. I'd swap that too if you do the sensor.
PhorB13 is offline
post #9 of 12 (permalink) Old 05-07-2008, 01:18 AM
classic lover
Quoted: 0 Post(s)
Feedback Score: 6 reviews
happened to me too coolant temp sensor was my problem
White/black bb powered 94 se-r sleeper
sr20monkey is offline
post #10 of 12 (permalink) Old 05-07-2008, 01:29 AM
Quoted: 0 Post(s)
Feedback Score: 55 reviews
well my car is the opposite way, when its cold and i turn the ignition on it will stay on but after a few seconds it will shut off, so i have to do this a couple of times till it finally stay on, its usually on the fourth time when the engine becomes warm that it will finally stay on, but i cant rev it that much or else it will shut off again, so basically i have to let it warm up for about 5 mins befere i can drive it. Any advice?
93 sentra xe dd (gas saver)
91 sentra se-r project car
97 200sx se-r new baby [/U]
99 sel
93 se -r
99sel-r is offline
post #11 of 12 (permalink) Old 05-07-2008, 05:34 PM
from FrontWD to RightWD
Quoted: 0 Post(s)
coolant temp sensors can cause both of your problems
budgetNX is offline
post #12 of 12 (permalink) Old 05-07-2008, 11:08 PM
agent camel toe
Quoted: 0 Post(s)
Feedback Score: 22 reviews
swap out the dizzy forst..u can get a used avenier dist on here for -$ and then get a new ect from the dealer
nyce1s.com
R.I.P. RESPECT SR.
96 b14 det--under the knife
2002 quest gxe--pimp wagon
t bags is offline
  SR20 Forum > Main Forums > SR20DE Technical Corner
User Tag List
