Old 09-25-2005, 09:22 PM   #1 (permalink)
the proof wizard
Trader Rating: 26 (100%)
rear brake piston question
simple question, can i use a C clamp on the rear caliper piston, or do our brakes call for that special tool? btw 92 b13 thanx
Old 09-25-2005, 09:29 PM   #2 (permalink)
SR powered S13 coupe
McCoy's Avatar
Trader Rating: 74 (100%)
Don't use a C clamp. Use a pair of pliers and twist them to retract the caliper.
Old 09-25-2005, 09:50 PM   #3 (permalink)
the proof wizard
hahah yea we jsut did. thanx a lot.
Old 09-25-2005, 10:47 PM   #4 (permalink)
Professor Dingbat
The tool is pretty cheap nowadays. You can use pliers to get it back, but if it is siezed, you can use a C-clamp to gently put pressure on it, and use a hammer and punch to spin the piston. This way will make you wish you had spent the money on the proper tool.
