Originally Posted by McCoy
If that's what she likes.
Stratton:
The OEM catchcan is plenty enough if you're running only N/A. Its simply there to stop blow-by going back into the crankcase (though the routing is kind of retarded, and gets valvecover blowby into the intake).
If you want to run an aftermarket catchcan while N/A (which is perfectly fine), get a nice emissions grade tube and T-section to run from the valvecover and crankcase area to the can, then the can tubes into the intake. It works just as if you're re-routing the stock catchcan (writeup is in tech library).
